Re: Who runs a 295/65/15 on a 68-70 Charger?
[Re: TC@HP2]
#3132424
03/26/23 11:45 AM
03/26/23 11:45 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Back in 2008 I put these on my 68 Charger stickshift car along with “then” new SS springs. They were closer on the front side to qtr.. From memory, they had about 1” clearance. Went out for a test session on a pretty deserted road near me. Did a burnout and1st test launch after little spinning they hooked and bent the leafs. permanently bent front segments. The rear axle moved forward during this and the tires got into the front part of the rear quarters. Cut the tires some and and messed up the wheel trim a little. I pulled those garbage springs off and went with Caltracs and 275-65-15s until they came out with 295/55-15 (which fit perfect and give me the width).
[Re: Chargerfan68]
#3132450
03/26/23 02:24 PM
03/26/23 02:24 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I used to run them back in the 80's. Now down to a normal stock look no more rake.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Chargerfan68]
#3132526
03/26/23 08:37 PM
03/26/23 08:37 PM
Posts: 153 North Texas
SOCAL
North Texas
Back in 2008 I put these on my 68 Charger stickshift car along with “then” new SS springs. They were closer on the front side to qtr.. From memory, they had about 1” clearance. Went out for a test session on a pretty deserted road near me. Did a burnout and1st test launch after little spinning they hooked and bent the leafs. permanently bent front segments. The rear axle moved forward during this and the tires got into the front part of the rear quarters. Cut the tires some and and messed up the wheel trim a little. I pulled those garbage springs off and went with Caltracs and 275-65-15s until they came out with 295/55-15 (which fit perfect and give me the width). So you recommend Caltracs? Do your 295/55s hook well?
[Re: 6PKRTSE]
#3132527
03/26/23 08:38 PM
03/26/23 08:38 PM
SOCAL
North Texas
I used to run them back in the 80's. Now down to a normal stock look no more rake. Did you like them back in the 80s?
[Re: SOCAL]
#3132581
03/27/23 12:35 AM
03/27/23 12:35 AM
Chargerfan68
New York, USA
Back in 2008 I put these on my 68 Charger stickshift car along with “then” new SS springs. They were closer on the front side to qtr.. From memory, they had about 1” clearance. Went out for a test session on a pretty deserted road near me. Did a burnout and1st test launch after little spinning they hooked and bent the leafs. permanently bent front segments. The rear axle moved forward during this and the tires got into the front part of the rear quarters. Cut the tires some and and messed up the wheel trim a little. I pulled those garbage springs off and went with Caltracs and 275-65-15s until they came out with 295/55-15 (which fit perfect and give me the width). So you recommend Caltracs? Do your 295/55s hook well? I can only say the newer SSsprings did not work at all in my case. They actually bent and stayed bent. Maybe an older set (pre-2000) are better quality? The Caltracs on my car work very well. The drag radials I run are MT ET Street and work pretty good on the street after a little heat is in them. Car pulls good with them. And the caltracs work very well at the track. Super consistent.
