Temp. sending unit leaking #3131718
03/23/23 03:10 PM
03/23/23 03:10 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
I installed a new 440 Source aluminum water pump housing on my 440 with a new aftermarket temperature sending unit. The sending unit leaked through the threads. I replaced the new sensor with my old stock unit and it also leaks. The leak is very small but it's still a leak. Can I put anything on the sending unit threads such as teflon tape or teflon paste (pipe dope) or will a sealant block the sensor's ground? Would a small rubber o ring work?
Thanks for any help.
Re: Temp. sending unit leaking [Re: markrr] #3131727
03/23/23 03:23 PM
03/23/23 03:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
try a bit of permatex brown usually works
Chrysler Firepower
Re: Temp. sending unit leaking [Re: therocks] #3131735
03/23/23 03:54 PM
03/23/23 03:54 PM
Central Pa
moparjim79 Online content
moparjim79  Online Content
Central Pa
Tape or dope is fine. Use both sparingly. Never a problem here, both iron and aluminum intakes...
Re: Temp. sending unit leaking [Re: moparjim79] #3131740
03/23/23 04:19 PM
03/23/23 04:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Permatex Pipe Sealant
You won't have a leak with this material. Just don't tighten it excessively or you probably won't get it out. Just a comment, the concern about insulating the sensor is misplaced, Pipe threads are tapered so the thread flanks will always have metal/metal contact. Thread sealant does nothing but fill the voids in the threads.
Re: Temp. sending unit leaking [Re: markrr] #3131752
03/23/23 05:39 PM
03/23/23 05:39 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
High temp silicone on threads. let it cure overnight
Re: Temp. sending unit leaking [Re: terzmo] #3131753
03/23/23 05:55 PM
03/23/23 05:55 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I have teflon tape near the top of the threads.
Re: Temp. sending unit leaking [Re: moparjim79] #3131778
03/23/23 07:47 PM
03/23/23 07:47 PM
IMGTX Offline
IMGTX  Offline
I agree.
The teflon tape & pipe dope fills the gaps in the threads but when you tighten the sensor down you will get metal to metal contact through much of the threads.
Re: Temp. sending unit leaking [Re: markrr] #3131784
03/23/23 08:04 PM
03/23/23 08:04 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree My stock temp gauge didn’t work at first with a new sensor that had PTFE tape on the threads, tightened it more and now it works up
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Temp. sending unit leaking [Re: metallicareload] #3131797
03/23/23 08:57 PM
03/23/23 08:57 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Perfect application for Never-Seez.
Re: Temp. sending unit leaking [Re: markrr] #3131798
03/23/23 09:00 PM
03/23/23 09:00 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
You installed a sensor into Aluminum & didn't use anything on the threads??
tsk tsk tsk tsk
Re: Temp. sending unit leaking [Re: PhillyRag] #3131811
03/23/23 10:27 PM
03/23/23 10:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Teflon tape or paste on NPT threads - always.
Re: Temp. sending unit leaking [Re: CMcAllister] #3131865
03/24/23 10:58 AM
03/24/23 10:58 AM
moparx Offline
moparx  Offline
i use loctite 567 paste for everything.
works with gasoline, oils, natural gas, propane, butane, potable water, water tanks, and any type of antifreeze.
good for any type of fittings as well.
been using this stuff for 40 years or so, and i really like it.
beer
Re: Temp. sending unit leaking [Re: moparx] #3131869
03/24/23 11:21 AM
03/24/23 11:21 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
beer
That's the Loctite equivalent of the Permatex 59214 I use. Good stuff whichever you choose. up
Re: Temp. sending unit leaking [Re: 6PakBee] #3131949
03/24/23 03:32 PM
03/24/23 03:32 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Thanks for the replies. I used the high temp silicone that I have.
Re: Temp. sending unit leaking [Re: PhillyRag] #3131951
03/24/23 03:42 PM
03/24/23 03:42 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
tsk tsk tsk tsk
No I didn't. I assumed, incorrectly, that sealant on the threads would impede the grounding between the sensor and the housing. Now I know better.
Re: Temp. sending unit leaking [Re: markrr] #3132195
03/25/23 02:42 PM
03/25/23 02:42 PM
moparx Offline
moparx  Offline
having to repair many threaded connections over the years where dis-similar materials were used, it doesn't take long to learn about anti-seize and sealants.
and stainless threaded connections are "fun" unto themselves. panic biggrin
beer
Re: Temp. sending unit leaking [Re: moparx] #3132375
03/26/23 08:32 AM
03/26/23 08:32 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Stainless steel thumb screws into aluminum rods at a seacoast
led me to create many new curse words.
I also made the mistake of assuming Dielectric Grease would hurt electrical connections
because I had been lectured over and over that
“Grounding connections to divert lightning strikes to Earth ground must be kept totally free of paint or visible corrosion”
Re: Temp. sending unit leaking [Re: 360view] #3132386
03/26/23 09:18 AM
03/26/23 09:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Same basic approach. I've had people tell me not to use dielectric grease on light bulbs "because it insulates the bulb". No, you still have electrical continuity at the mechanical contact points. The grease just fills the voids to prevent corrosion.
Re: Temp. sending unit leaking [Re: moparx] #3132492
03/26/23 05:19 PM
03/26/23 05:19 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
beer
Brass fittings seem to be the cure when used in aluminum. Have always been able to easily remove the brass ones from my swap meet intake buys while the steel fittings give me giant headaches.
