Re: Reverse Indicator Lamp 1969 road runner
[Re: Stanton]
#3131349
03/22/23 09:39 AM
03/22/23 09:39 AM
Posts: 3,529 Lansing, MI
70gtx440dana
Lansing, MI
It goes to the "Z" terminal location on the bulkhead connector. Your new harness should have had a female connector with it.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#3131434
03/22/23 12:52 PM
03/22/23 12:52 PM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
It goes to the "Z" terminal location on the bulkhead connector. Your new harness should have had a female connector with it. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) It would appear our cheap a-s repops do not include the 5 cent terminal ![flame flame](/ubbthreads/images/graemlins/custom/flame.gif) Pictured is an NOS unit
[Re: Air Grabbler]
#3131438
03/22/23 01:14 PM
03/22/23 01:14 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
Here's what I have from my '69 4-speed GTX that I think would be the same? Also included is the wiring harness comparison for an automatic and 4-speed. And yes terminal "Z" as 70gtx440dana stated ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Mike
[Re: topside]
#3131468
03/22/23 02:56 PM
03/22/23 02:56 PM
70gtx440dana
Lansing, MI
A12 - Any pics of the factory connection for the tach harness at the back of the fuse box. I cannot find this info in any harness diagrams either. I have been told it is connected to the accessory fuse.
[Re: 70gtx440dana]
#3131701
03/23/23 02:02 PM
03/23/23 02:02 PM
A12
N.E. OHIO, USA
A12 - Any pics of the factory connection for the tach harness at the back of the fuse box. I cannot find this info in any harness diagrams either. I have been told it is connected to the accessory fuse. Do you know the color of the tach wire? Would it happen to be dark blue (dk blue as shown in the '69 B-body Plymouth/Dodge wiring diagram? If so then I hope this answers your question? Mike
[Re: NITROUSN]
#3131723
03/23/23 03:14 PM
03/23/23 03:14 PM
A12
N.E. OHIO, USA
Tach wire is commonly gray to coil - reference signal and Blue from fuse block to tach 12 volt feed.. A12 - Any pics of the factory connection for the tach harness at the back of the fuse box. I cannot find this info in any harness diagrams either. I have been told it is connected to the accessory fuse.
Thanks NITROUSN, the blue wire to the fuse was the question ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Air Grabbler]
#3131888
03/24/23 12:33 PM
03/24/23 12:33 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Thanks everyone! I will be tackling this tomorrow morning and am confident that I'll be successful thanks to your help. I'll report back tomorrow. Remember that the ground is it being bolted to the cluster which is bolted to the body , many resto paint places the factory never painted and this can cause issues with grounds.
[Re: A12]
#3131955
03/24/23 03:48 PM
03/24/23 03:48 PM
70gtx440dana
Lansing, MI
A12 - Any pics of the factory connection for the tach harness at the back of the fuse box. I cannot find this info in any harness diagrams either. I have been told it is connected to the accessory fuse. Do you know the color of the tach wire? Would it happen to be dark blue (dk blue as shown in the '69 B-body Plymouth/Dodge wiring diagram? If so then I hope this answers your question? Mike Mike, Thanks a million ...yes the tach wire is blue and your photo confirms the location @ the accessory fuse!!!! I have two 69 wiring diagrams (Dodge and Plymouth) and they do not show this blue tach wire. Your diagrams pictured above are the best I have seen. Any chance you can email them? If so, send me a PM.
