Reverse Indicator Lamp 1969 road runner #3131284
03/21/23 11:03 PM
03/21/23 11:03 PM
WA
Air Grabbler Offline OP
WA
Howdy all,
I'm working on my 1969 4 speed road runner. When I got the car the reverse indicator lamp was missing from the dash, and it had no reverse lamp wiring harness that plugs into the switch on the transmission. I bought a new harness and a reverse indicator lamp for the dash. I've studied the wiring diagrams in the service manual but cannot locate the dash lamp on any drawings. The lamp I bought has a plain black wire with no connector on the end. My question: where do you connect this wire? Thanks for any help.
Re: Reverse Indicator Lamp 1969 road runner [Re: Air Grabbler] #3131335
03/22/23 08:27 AM
03/22/23 08:27 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I replied to you on FBBO.
Re: Reverse Indicator Lamp 1969 road runner [Re: Stanton] #3131349
03/22/23 09:39 AM
03/22/23 09:39 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
It goes to the "Z" terminal location on the bulkhead connector. Your new harness should have had a female connector with it.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Reverse Indicator Lamp 1969 road runner [Re: 70gtx440dana] #3131434
03/22/23 12:52 PM
03/22/23 12:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
It would appear our cheap a-s repops do not include the 5 cent terminal flame flame
Pictured is an NOS unit
Re: Reverse Indicator Lamp 1969 road runner [Re: Air Grabbler] #3131438
03/22/23 01:14 PM
03/22/23 01:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's what I have from my '69 4-speed GTX that I think would be the same? Also included is the wiring harness comparison for an automatic and 4-speed.
And yes terminal "Z" as 70gtx440dana stated up
Mike
Re: Reverse Indicator Lamp 1969 road runner [Re: A12] #3131445
03/22/23 01:36 PM
03/22/23 01:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ That's good info right there !
Re: Reverse Indicator Lamp 1969 road runner [Re: topside] #3131468
03/22/23 02:56 PM
03/22/23 02:56 PM
Lansing, MI
Lansing, MI
A12 - Any pics of the factory connection for the tach harness at the back of the fuse box. I cannot find this info in any harness diagrams either. I have been told it is connected to the accessory fuse.
Re: Reverse Indicator Lamp 1969 road runner [Re: 70gtx440dana] #3131477
03/22/23 03:34 PM
03/22/23 03:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'll do a search of my photos as my GTX also has a tach.
Re: Reverse Indicator Lamp 1969 road runner [Re: 70gtx440dana] #3131701
03/23/23 02:02 PM
03/23/23 02:02 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Do you know the color of the tach wire? Would it happen to be dark blue (dk blue as shown in the '69 B-body Plymouth/Dodge wiring diagram? If so then I hope this answers your question?
Mike
69 wiring instrument etc 002.jpg69 wiring instrument etc 001.jpgDSC04877.JPGDSC04878.JPG
Re: Reverse Indicator Lamp 1969 road runner [Re: A12] #3131713
03/23/23 02:52 PM
03/23/23 02:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Tach wire is commonly gray to coil - reference signal and Blue from fuse block to tach 12 volt feed..
Re: Reverse Indicator Lamp 1969 road runner [Re: NITROUSN] #3131723
03/23/23 03:14 PM
03/23/23 03:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
Thanks NITROUSN, the blue wire to the fuse was the question up
Re: Reverse Indicator Lamp 1969 road runner [Re: A12] #3131823
03/23/23 11:29 PM
03/23/23 11:29 PM
WA
WA
Thanks everyone! I will be tackling this tomorrow morning and am confident that I'll be successful thanks to your help. I'll report back tomorrow.
Re: Reverse Indicator Lamp 1969 road runner [Re: Air Grabbler] #3131828
03/23/23 11:44 PM
03/23/23 11:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Reverse Indicator Lamp 1969 road runner [Re: Air Grabbler] #3131888
03/24/23 12:33 PM
03/24/23 12:33 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Remember that the ground is it being bolted to the cluster which is bolted to the body , many resto paint places the factory never painted and this can cause issues with grounds.
Re: Reverse Indicator Lamp 1969 road runner [Re: A12] #3131955
03/24/23 03:48 PM
03/24/23 03:48 PM
Lansing, MI
Lansing, MI
Mike
Mike, Thanks a million ...yes the tach wire is blue and your photo confirms the location @ the accessory fuse!!!! I have two 69 wiring diagrams (Dodge and Plymouth) and they do not show this blue tach wire. Your diagrams pictured above are the best I have seen. Any chance you can email them? If so, send me a PM.
Re: Reverse Indicator Lamp 1969 road runner [Re: JohnRR] #3131970
03/24/23 05:40 PM
03/24/23 05:40 PM
WA
WA
I got everything functioning, thanks to your help. My car now has a reverse indicator lamp and functioning back-up lights for the first time in probably 30-40 years (I've only owned it for a couple months and am sorting out dozens of little issues). It's the small victories that keep us going, ha ha.
Re: Reverse Indicator Lamp 1969 road runner [Re: Air Grabbler] #3131975
03/24/23 05:49 PM
03/24/23 05:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
beer
Re: Reverse Indicator Lamp 1969 road runner [Re: A12] #3132196
03/25/23 02:43 PM
03/25/23 02:43 PM
moparx Offline
moparx  Offline
it makes a guy feel SO good when a stubborn issue is resolved. boogie
beer
Re: Reverse Indicator Lamp 1969 road runner [Re: 70gtx440dana] #3132459
03/26/23 02:55 PM
03/26/23 02:55 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
up beer (your PM thanks) beer up
Mike
