Re: Turbo to NSS Conversion Progress
[Re: dizuster]
#3131997
03/24/23 07:21 PM
03/24/23 07:21 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
This was probably the hardest to do, especially because the hood color already matches the car so poorly.
But I think overall the scoop "fits the look" with the way I did it.
[Re: dizuster]
#3132028
03/24/23 08:59 PM
03/24/23 08:59 PM
Posts: 3,085 Michigan
A727Tflite
Hey Scott, I really like the idea of the paper towel holder on the core support in your first picture. The image of the rear door shell cut out reminds me of Jimmy Addison when he did the same to the 62 Dodge he bought from my dad and raced before the Bullet. He also took most of the rear seat upper and lower wire frame and cut that out too.
[Re: dizuster]
#3132041
03/24/23 10:34 PM
03/24/23 10:34 PM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
I was SHOCKED that a 29.5 x 10.5 Bracket Radial Pro fit the stock wheel well. What size rim and BS are you using on the rear?
[Re: dizuster]
#3132102
03/25/23 09:42 AM
03/25/23 09:42 AM
Posts: 4,071 Mo.
racerx
Mo.
And of course... if you didn't catch the other thread. Motor is almost done. Killer looking engine .....i guest the old saying going boosted you will never look back isn't true Good luck with it.
[Re: dizuster]
#3132105
03/25/23 09:47 AM
03/25/23 09:47 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Love it. Looking great. Keep the pics coming.
Rich H.
Esse Quam Videri
[Re: dizuster]
#3132188
03/25/23 02:20 PM
03/25/23 02:20 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
I'm thinking your using the original 343 HP 383 motor option for this build, yes or no ?
[Re: max_maniac]
#3132404
03/26/23 10:28 AM
03/26/23 10:28 AM
dizuster
Oakland, MI
I was SHOCKED that a 29.5 x 10.5 Bracket Radial Pro fit the stock wheel well. What size rim and BS are you using on the rear? 15 x 10" Rim with 4.75" back space (give er' take an 1/8") The spring is also moved in SLIGHTLY, but the wheel well is not the limitation, it's still the spring.
[Re: Whompin_Wedge]
#3132405
03/26/23 10:30 AM
03/26/23 10:30 AM
dizuster
Oakland, MI
Can not wait to see this thing hit the track!
I am however upset you removed the interior..... I still miss the looks of the bench seats in the Coronet.
Casey FJ 1,00,000% agree with you. I must be getting old because I decided the risk of crashing with the unattached bench seat, and only 4 old 1962 studs holding that behemoth in was a bad idea. I only did it for safety, because if it was just weight and ET I would rather have been slow and kept the look!
[Re: Cab_Burge]
#3132407
03/26/23 10:31 AM
03/26/23 10:31 AM
dizuster
Oakland, MI
I'm thinking your using the original 343 HP 383 motor option for this build, yes or no ? Cab, the NSS racing can use any engine combo and you just pick your class. There is no HP factor or anything like that. If you pick 10.00 index, you just run that all weekend.
[Re: dizuster]
#3132410
03/26/23 10:37 AM
03/26/23 10:37 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Really digging the whole aesthetic of your '62, matching the scoop's patina to the rest of the car is awesome. I love the wheel and tire choice too!
[Re: fbs63]
#3132600
03/27/23 06:00 AM
03/27/23 06:00 AM
Posts: 10,033 MN
JERICOGTX
MN
Progress looks good. The swingout pin location wouldn't pass an NHRA cert with our local inspector. Supposed to be less than 6" center of the pin, to the bar, using the furthest point. Might want to check with your local inspector before getting the cage certified.
69 GTX
68 Road Runner
