7 /16" comp cams pro magnum rocker adjuster (female cup) #3131068
03/21/23 11:24 AM
03/21/23 11:24 AM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I broke one setting the lash (which i didn't think was possible)
does anybody know of a source for these? they look to be 7/16 fine thread with a 3/8" ball cup (female at the bottom of the adjuster for Ball end pushrods). I can't find them in the ARP catalog and Comps Tech support is impossible to get a hold of. I thought these would be an advantage over the stud type but I soon realized that if one of them breaks you have to take off the entire rocker shaft to replace it since the stud has a collar below the rocker.
Trying to get ready for Mopars at the Rock in a couple weeks, I didn't even think it was possible to shear one just tightening the lash with a wrench, I'm wondering if the metallurgy is bad?
WIZE
In Car:
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Streetwize] #3131072
03/21/23 11:36 AM
03/21/23 11:36 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Bad news. First I have heard of one breaking.
T&D and Manton show them but not sure if they are an exact match.
Rich H.
Esse Quam Videri
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: ZIPPY] #3131082
03/21/23 12:06 PM
03/21/23 12:06 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have purchased adjusters from Smith Brothers Pushrods in the past.
You might check with them.
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: 340Cuda] #3131111
03/21/23 01:18 PM
03/21/23 01:18 PM
tsk twocents
Mantons are way better than Smith Bros up scope Don't ask me how I know that rant puke whistling
if one broke, how close are the other 15, I would replace them all now and use these for spares later, if you will ever needed some twocents
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Cab_Burge] #3131121
03/21/23 01:53 PM
03/21/23 01:53 PM
Weddington, N.C.
Weddington, N.C.
Cab,
Exactly what I was thinking. I turn it like 7200 with cold lash at .012 and .014 (~.018/.020 hot) and the lash holds steady They're strong rockers, I 'm just a little gun-shy now
Thanks!
WIZE
In Car:
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Cab_Burge] #3131140
03/21/23 02:24 PM
03/21/23 02:24 PM
Washington
madscientist Offline
Washington
tsk twocents
And yet, per a guy who would know, Smith Brothers supplies most NASCAR teams. So yeah, it must be junk.
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: madscientist] #3131143
03/21/23 02:35 PM
03/21/23 02:35 PM
Weddington, N.C.
Weddington, N.C.
Manton lists the adjuster at $19.00 a piece. I think I can find a set somewhere for $50-60 hopefully,
WIZE
In Car:
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Streetwize] #3131160
03/21/23 03:34 PM
03/21/23 03:34 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Without Data, you’re just another guy with an opinion.
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: sr4440] #3131161
03/21/23 03:39 PM
03/21/23 03:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Harland Sharp price per (4)
If you think the damage was your fault the others should be fine. If it was a wear issue change them out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: madscientist] #3131279
03/21/23 10:42 PM
03/21/23 10:42 PM
tsk twocents
Since when? According to them or from actual race teams?
I've had bad products from Smith Bros back when they were in West Covina, CA in 1969 puke They use to supply almost all the cam companies in SO CA back then when the original owners were making and selling their products, Changes in quality, lack of, and pricing changed all that hence Manton, Trend and other companies taking over the market scopeshruggy work scope
I could go on and on about my personal bad experiences with them but that isn't productive so I won't..
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Streetwize] #3131303
03/22/23 01:19 AM
03/22/23 01:19 AM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
I had one break as well. In my case, it was pretty clear operator error (dropped the rocker). I decided to replace them all and ordered the PRW set. Limited use, but so far so good. If you want, I can check the shop and maybe send you a used one. Send me a message.
This space not for rent.
Re: 7 /16" comp cams pro magnum rocker adjuster (female cup) [Re: Bill_T] #3131330
03/22/23 08:18 AM
03/22/23 08:18 AM
Weddington, N.C.
Weddington, N.C.
Thanks Bill, I just PM'ed you Cheers!
WIZE
In Car:
