Engine Paint. #31300
09/27/06 07:08 AM
09/27/06 07:08 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Does anyone have a Base/clear paint code # for the correct shade of Hemi Orange paint? I have a few engines that are ready for paint and figure that I can paint urethane base/clear with a flattener and achieve good results. I have done one already in "mandarin orange", and while it looks very nice, it's just a little off.
Anyone??
Mike
Re: Engine Paint. [Re: HPMike] #31301
09/27/06 10:29 AM
09/27/06 10:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
perfect timing , i need to paint my engine and an air cleaner for a friend , though i'll just do a single stage ??? no clear coat here .
mike theres a thread started by djvcuda bashing bill hirsh paint that i think had some info on other paint and codes ?
Re: Engine Paint. [Re: JohnRR] #31302
09/27/06 11:03 AM
09/27/06 11:03 AM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Roger Gibson has the right stuff. I have seen motors done with clear and I think they are way too shiny. The OEM formula would be single stage...
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: Engine Paint. [Re: sg333e] #31303
09/27/06 11:59 AM
09/27/06 11:59 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
As stated in the original post, I have used a flattener in the clear and it worked out great, not too shiny. All I need is the correct color. The urethane base/clear is truly superior, especially for those who actually DRIVE or RACE their cars. The paint will hold up to anything you put to it. If you use the Gibson stuff without a gloss hardener, the paint will fall off the motor the minute it comes into contact with fuel or brake cleaner, etc.
Codes, anyone????
Mike
Re: Engine Paint. [Re: HPMike] #31304
09/27/06 12:06 PM
09/27/06 12:06 PM
I think this was discussed in depth about 5mo ago.Mike R probably saved all the info.
Re: Engine Paint. #31305
09/27/06 12:22 PM
09/27/06 12:22 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I did a search on the word "mandarin" in the A12 Restoration forum, here is the thread https://board.moparts.org/ubbthreads/show...rue#Post2382148
AZ A12 Bee has an attached photo of the paint code on the can of paint. I've attached the photo also.
Re: Engine Paint. [Re: Dave Watt] #31306
09/27/06 03:51 PM
09/27/06 03:51 PM
Lynch Road / St. Louis
bebeep1969 Offline
bebeep1969  Offline
mandarin orange is correct
Re: Engine Paint. [Re: JohnRR] #31307
09/27/06 04:22 PM
09/27/06 04:22 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
here is the thread you are talking about... https://board.moparts.org/ubbthreads/show...part=1&vc=1
i have to agree the enamel that bill hirsh sells is just old school junk...
djv used U-tech 3.8 on a few motors including mine and it is some great stuff. looks great and has held awesome.. looks as good almost 2 years later as it did the day it was sprayed and my car sits out side all the time....
here is the info from the can of paint that was used on my motor....
it is U-tech 3.8 ( its a high solids urathane single stage paint)
yr. 1960 mfg: dupont code: 5067u
color: orange
sfx: k sys: 4 voc: 0.36
mixed 10-23-04
contains lead.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Engine Paint. [Re: abodyjoe] #31308
09/27/06 04:26 PM
09/27/06 04:26 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
Re: Engine Paint. [Re: abodyjoe] #31309
09/27/06 06:19 PM
09/27/06 06:19 PM
montreal,quebec,canada
buzz440 Offline
buzz440  Offline
Anyone use the POR-15 engine paint? I hear the
color is right and it's pretty tough
I haven't used it..... just inquiring.
Later, BUZZ
Re: Engine Paint. [Re: buzz440] #31310
09/27/06 07:03 PM
09/27/06 07:03 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i have used 2 coats of epoxy primer and 2 coats of u-tech 3.8 for 3 engines now... I will NEVER use anything else, that bill hirsh garbage is weak, the u-tech is capable of withstanding brake cleaner, or anything else you throw at it... my engine caught fire, adn I cleaned it up with brake cleaner and dtarting fuild... it just washed the soot away, to reveal clean paint!
Re: Engine Paint. [Re: sg333e] #31311
09/27/06 09:46 PM
09/27/06 09:46 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
all Gibson does is repackage paint you can just go down to the local store and buy without the middleman mark up
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Engine Paint. [Re: buzz440] #31312
09/27/06 10:31 PM
09/27/06 10:31 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Later, BUZZ
I used it. Looks good to me. Not sure about correct though.
Re: Engine Paint. [Re: DJVCuda] #31313
09/28/06 05:06 PM
09/28/06 05:06 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
I was told too much paint can hold in a lot of heat.
Isn't that a lot of paint on the motor? Does it hold in too much heat?
MikeE
Who knows? The Shadow Knows! But he ain't on this fraking forum! "This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!" -------------------------------
Re: Engine Paint. [Re: abodyjoe] #31314
04/16/07 11:15 PM
04/16/07 11:15 PM
hello,
i have to repaint my 440 6 pack engine and engine compartment and want your input on the proper paint for the job??
any suggestions??
thanks in advance,
bob
Re: Engine Paint. [Re: sg333e] #31315
04/17/07 08:18 AM
04/17/07 08:18 AM
sixbbl69 Offline
sixbbl69  Offline
primer is a big waste of time as is base clear. acrylic enamel with hardner or a good single stage is all you need.the more paint [primer] you use on your engine the sooner it will fall off in big chunks.most low gloss engines look like they were painted with spray cans.i will take the Roger Gibson look any day over the home brewed spray can look.
Re: Engine Paint. [Re: sixbbl69] #31316
05/09/07 10:31 AM
05/09/07 10:31 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I just used the Mandarin Orange in a single stage (DAR 3116 H) which is for a 79 AMC (easier to find the recipe) It looks great! Thanks for the info. Trying to get it together for Mopar in the Park (MN) June 2-3. Dropped the tranny on my arm sunday night- so I'm slowed up a bit. Amazing the numbing effect of beer isn't it? Should have a pulse for the first time since 1986, I can't wait to hear it!
Re: Engine Paint. [Re: sixbbl69] #31317
05/09/07 12:34 PM
05/09/07 12:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
spray bombs work me me , i 'em , not sit around with the hood/off open sipping umbrella drinks
Re: Engine Paint. [Re: JohnRR] #31318
05/09/07 03:04 PM
05/09/07 03:04 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Now you're gonna hurt the feelings of all the guys that like umbrella drinks, you insensitive clod!!
J/K, I also used a spray bomb on mine (Plastikote Hemi Orange) and frankly, most of the spray booth, base clear, bodyshop engine jobs I've seen looked way too glossy and usually the wrong color. I'm sure some people (like HPMike) have nailed it down using those methods, but it seems like overkill to me and trust me; I've gone off the deep end on some other details (many that can't even be seen!). Honestly, before threads like this on Moparts, it wouldn't have ever occured to me to do it any other way. In the old days, the only guys I remember with bodyshop paintjobs on thier motors were the ones with color matched engine blocks and chrome everything.
......what did the factory use, anyway? None of my original engines looked any better than a good spray-bomb job.
Anywho, to each thier own.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Engine Paint. [Re: JohnRR] #31319
05/09/07 03:15 PM
05/09/07 03:15 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
Spray bomb works for me and I love to my car.
BTW, what's wrong with Foo-foo drinks
