Re: Engine Paint.
[Re: JohnRR]
#31302
09/27/06 11:03 AM
09/27/06 11:03 AM
Posts: 1,267 midwest
sg333e
super street
super street
midwest
Roger Gibson has the right stuff. I have seen motors done with clear and I think they are way too shiny. The OEM formula would be single stage...
Hobbies and associated message boards:
1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com
1987 Grand National (422rwhp/566tq)> TurboBuick.com
2008 BMW 335 TT 6MT> E90Post.com
2008 Gary Fisher HiFi Plus 29er > MTBR.com
2008 German Shorthair Pointer > Shorthairs.net
Re: Engine Paint.
[Re: HPMike]
#31304
09/27/06 12:06 PM
09/27/06 12:06 PM
I think this was discussed in depth about 5mo ago.Mike R probably saved all the info.
Re: Engine Paint.
[Re: JohnRR]
#31307
09/27/06 04:22 PM
09/27/06 04:22 PM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
perfect timing , i need to paint my engine and an air cleaner for a friend , though i'll just do a single stage ??? no clear coat here .
mike theres a thread started by djvcuda bashing bill hirsh paint that i think had some info on other paint and codes ?
here is the thread you are talking about... https://board.moparts.org/ubbthreads/show...part=1&vc=1
i have to agree the enamel that bill hirsh sells is just old school junk...
djv used U-tech 3.8 on a few motors including mine and it is some great stuff. looks great and has held awesome.. looks as good almost 2 years later as it did the day it was sprayed and my car sits out side all the time....
here is the info from the can of paint that was used on my motor....
it is U-tech 3.8 ( its a high solids urathane single stage paint)
yr. 1960 mfg: dupont code: 5067u
color: orange
sfx: k sys: 4 voc: 0.36
mixed 10-23-04
contains lead.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
Re: Engine Paint.
[Re: buzz440]
#31312
09/27/06 10:31 PM
09/27/06 10:31 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Anyone use the POR-15 engine paint? I hear the color is right and it's pretty tough I haven't used it..... just inquiring.
Later, BUZZ
I used it. Looks good to me. Not sure about correct though.
Re: Engine Paint.
[Re: DJVCuda]
#31313
09/28/06 05:06 PM
09/28/06 05:06 PM
Posts: 4,150 VA
RapidRunner
VA
i have used 2 coats of epoxy primer and 2 coats of u-tech 3.8 for 3 engines now... I will NEVER use anything else, that bill hirsh garbage is weak, the u-tech is capable of withstanding brake cleaner, or anything else you throw at it... my engine caught fire, adn I cleaned it up with brake cleaner and dtarting fuild... it just washed the soot away, to reveal clean paint!
I was told too much paint can hold in a lot of heat. Isn't that a lot of paint on the motor? Does it hold in too much heat?
MikeE
Who knows? The Shadow Knows! But he ain't on this fraking forum!
"This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!"
Re: Engine Paint.
[Re: abodyjoe]
#31314
04/16/07 11:15 PM
04/16/07 11:15 PM
hello, i have to repaint my 440 6 pack engine and engine compartment and want your input on the proper paint for the job?? any suggestions?? thanks in advance, bob
Re: Engine Paint.
[Re: JohnRR]
#31318
05/09/07 03:04 PM
05/09/07 03:04 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
primer is a big waste of time as is base clear. acrylic enamel with hardner or a good single stage is all you need.the more paint [primer] you use on your engine the sooner it will fall off in big chunks.most low gloss engines look like they were painted with spray cans.i will take the Roger Gibson look any day over the home brewed spray can look.
spray bombs work me me , i 'em , not sit around with the hood/off open sipping umbrella drinks
Now you're gonna hurt the feelings of all the guys that like umbrella drinks, you insensitive clod!!
J/K, I also used a spray bomb on mine (Plastikote Hemi Orange) and frankly, most of the spray booth, base clear, bodyshop engine jobs I've seen looked way too glossy and usually the wrong color. I'm sure some people (like HPMike) have nailed it down using those methods, but it seems like overkill to me and trust me; I've gone off the deep end on some other details (many that can't even be seen!). Honestly, before threads like this on Moparts, it wouldn't have ever occured to me to do it any other way. In the old days, the only guys I remember with bodyshop paintjobs on thier motors were the ones with color matched engine blocks and chrome everything.
......what did the factory use, anyway? None of my original engines looked any better than a good spray-bomb job.
Anywho, to each thier own.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: Engine Paint.
[Re: JohnRR]
#31319
05/09/07 03:15 PM
05/09/07 03:15 PM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
Spray bomb works for me and I love to my car.
BTW, what's wrong with Foo-foo drinks
