Machine shop rates in SE Michigan #3130307
03/18/23 11:23 AM
03/18/23 11:23 AM
A727Tflite Offline OP
Wondering what some of you have recently paid in the SE Michigan tri-county area for:
Bore/hone
Cam bearing install
Equalize and parallel cut decks
Degrease
Balance (internally)
Looking for some suggestions on shops to use too.
I know, I can call all these shops, looking for recent experience on quality and what you actually ended up paying.
Re: Machine shop rates in SE Michigan [Re: A727Tflite] #3130319
03/18/23 11:49 AM
03/18/23 11:49 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
i dont know about anyone elses area.but in st.louis it takes a year to get back from a simple bore and hone,decked and cam bearins.so i stopped going that route and started buying engines done.which cant find any.like everything in these times
Re: Machine shop rates in SE Michigan [Re: dart games] #3130322
03/18/23 12:07 PM
03/18/23 12:07 PM
birdtracker Offline
birdtracker  Offline
I recently had a block degreased and honed and it was $150
I had the heads decked and a valve job done, springs checked. $400.
I assembled everything. I am north of Dayton Ohio Birdtracker
Re: Machine shop rates in SE Michigan [Re: A727Tflite] #3130323
03/18/23 12:19 PM
03/18/23 12:19 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Most recently all of the engine block mchining, balancing and crank prep, along with some head work for my W2 stroker build was done by Fastime Racing, they are at 12254 Universal Dr., Taylor, MI 48180.
Previously I had my factory '596 head casting epoxy patched by them (during my DIY porting work I managed to uncover a pinhole sized casting porosity that connected the exhaust port to the cooling feed - so most likely it was already pretty thin in that area regardless). They pressure tested the head to find this, took several tried b/c the stuff was in the exhaust cross-over area, so hard to reach. They prepped the head after, did the epoxy work, which than lasted for about 5 seasons of weekend street use, so plenty of heating /cooling cycles, which I thought was a darn good result.
They are very good people...genuine, no BS kind of a shop. The owners are proud of the work they do. I was originally referred to them by a local racer (whom I've known for some years now and have a good relationship with) that does performance work locally (engine builds, etc.). He does all his machining at their shop. They also race against each other, so there is some real world feel to the work the do.
Some years ago they used to have their price sheet posted on line, I can't find it on their site anymore, so I've attached the last one I saved up, which is 2015...so prices I'm sure have changed since.
Attached PDF document
Re: Machine shop rates in SE Michigan [Re: Diplomat360] #3130331
03/18/23 12:41 PM
03/18/23 12:41 PM
Thanks, great info.
Re: Machine shop rates in SE Michigan [Re: A727Tflite] #3130334
03/18/23 12:50 PM
03/18/23 12:50 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
I had about 2200.00 in labor for an RB including assembly 3 yrs ago. That's in W Md.
America First!
Re: Machine shop rates in SE Michigan [Re: carnut68] #3130353
03/18/23 03:14 PM
03/18/23 03:14 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I just picked my engine up from the shop I used in the Grand Rapids, MI area a few weeks ago and here is what they charged for the operations you asked about:
Bore/hone w/plate $329.00
Install cam bearings $65.00
Deck block $175.00
Degrease/inspect block $125
Balance (internal) $245.00
Re: Machine shop rates in SE Michigan [Re: IROC78] #3130417
03/18/23 07:54 PM
03/18/23 07:54 PM
Deck block $175.00
Thanks for the info.
Re: Machine shop rates in SE Michigan [Re: A727Tflite] #3130593
03/19/23 04:05 PM
03/19/23 04:05 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Bore/hone
Cam bearing install
Degrease
I know it isn't very recent, but I had my receipt for the last round of machine work I had done just sitting next to the computer.
Sonic test: $110
Decking block .005": $100
Balance rotating assembly: $225
Align hone mains: $155
Bore cylinders .030": $180
Degrease and clean: $100
Hone /w torque plate: $120
Cam bearings: $40
The above was done in 2017 by Superior Engine in Kimball. Used an internal blanaced 440 Source rotating kit that already had a rough balance. Phil was talking about retiring around 2019. Don't know if the shop is still operating.
Re: Machine shop rates in SE Michigan [Re: MarkZ] #3130603
03/19/23 04:28 PM
03/19/23 04:28 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I don’t think I would put much stock in a work order from 2017. Heck my 2 and 4 haircut went from 13.00-15.00-20.00 in one year. And it takes my barber around 7-8 minutes max.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Machine shop rates in SE Michigan [Re: pittsburghracer] #3130900
03/20/23 04:19 PM
03/20/23 04:19 PM
moparx Offline
moparx  Offline
which one did ya get cut ? biggrin [as my old man used to say. i couldn't resist. laugh2]
beer
Re: Machine shop rates in SE Michigan [Re: MarkZ] #3134069
03/31/23 11:36 PM
03/31/23 11:36 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Originally Posted by MarkZ
The above was done in 2017 by Superior Engine in Kimball. Used an internal balanced 440 Source rotating kit that already had a rough balance. Phil was talking about retiring around 2019. Don't know if the shop is still operating.
Doesn't look good. A quick search online revealed a facebook page that hasn't been updated since 2016. The business website link on that facebook page fails...the site is gone.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Machine shop rates in SE Michigan [Re: MarkZ] #3134123
04/01/23 09:57 AM
04/01/23 09:57 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Just recently the shop in my town quoted $500 to bore a 360 Magnum block .030, line hone the mains and cam tunnel, hot tank, new cam bearings and new core plugs installed.
Keep old mopars alive.
