Centerline Auto Drags and 5/8 wheel studs?
#3129367
03/14/23 03:28 PM
03/14/23 03:28 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Is there a way (path) to running 5/8 wheel studs on Centerline Auto Drag wheels? If so, in layman's terms....How?
Sorry... this is new territory for me.....
Thank you in advance
Curator at Adams County Speed Shop
Re: Centerline Auto Drags and 5/8 wheel studs?
[Re: 340man4ever]
#3129371
03/14/23 03:31 PM
03/14/23 03:31 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
If they already take a shank style lugnut they should slide right over the studs with no modification. As long as the wheel is flat where the nuts hold down there should be no issue.
If they are acorn seat I can't help you, but I don't think those are acorn seat.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3129374
03/14/23 03:44 PM
03/14/23 03:44 PM
Posts: 11,654 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
They should be close. The hole in the wheel is right for the shank of the lug nuts, which are about the same as a 5/8 stud shank.
Not all of the studs are the same, some are machined double ended studs, some are just bolts with sleeves.
If the wheels have been used on 1/2 studs with washers, the hole could be buggered a bit.
Use a file, or a brake cylinder hone to massage the holes to size. It would be good to have a stud in hand to check each hole. Do not use a drill bit or get in there with a die grinder unless you do it gently with a flapper wheel.
A proper fit still requires some wiggling to get them on and off. If they fall on easily, the holes are too big.
Been there, done that. I remember some of those old Certerlines being like that. Lots of people used them in the day. Too bad they closed up.
[Re: '72CudaRacer]
#3129469
03/14/23 08:08 PM
03/14/23 08:08 PM
Posts: 1,366 Out of the State of Confusion
blue_stocker
I used CL auto drags on my stocker for years with Strange axles with 5/8 studs, They fit right over the studs and the Strange studs have an alumium spacer then the nut goes right on top...DONE!
Here is one of the Strange 5/8" wheel stud arrangements. It's basically a 5/8" unf grade 8 bolt, threaded sleeve that goes over the stud and against the axle flange/brake drum/rotor, the spacer/washer and the nut. It works quite well. MW and Strange also have another stud arrangement that is threaaded on both ends and has and over-sized body (between the threads) where the wheel 'rides' on it...slop is minimal.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: hemienvy]
#3129484
03/14/23 09:28 PM
03/14/23 09:28 PM
340man4ever
Creston, Iowa
Thank you all for the responses and help, much appreciated!
[Re: 340man4ever]
#3129507
03/14/23 10:38 PM
03/14/23 10:38 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As an FYI, the bolt with a sleeve deal from Strange is a PIA. The correct length, machined, double end studs, also from Strange, are about the same money and much nicer.
[Re: 340man4ever]
#3129586
03/15/23 10:55 AM
03/15/23 10:55 AM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
My Centerline Warrior wheels had to be opened up slightly to fit 5/8" studs. Not much, but a little. Took my time and did it w/ a drill.
