Stamped valve covers on TrickFlow heads? #3127606
03/08/23 07:33 PM
03/08/23 07:33 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I'd really like to run some vintage B/RB Direct Connection valve covers with TrickFlow heads on a street car. Has anyone run stamped covers on these heads? Is it possible? [Heads are not in my possession yet so I can't trial fit..]
Re: Stamped valve covers on TrickFlow heads? [Re: WarEagle1] #3127644
03/08/23 09:21 PM
03/08/23 09:21 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Bolt hole alignment might not be great. For whatever reason the TF bolt hole location is a bit off versus the average of other heads. Other than that I think they should work. I have TF270 heads. In an older thread I posted the TF270 bolt hole locations along with some other heads.
Re: Stamped valve covers on TrickFlow heads? [Re: markz528] #3127723
03/09/23 07:27 AM
03/09/23 07:27 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have them on mine. No issues
Re: Stamped valve covers on TrickFlow heads? [Re: WarEagle1] #3127726
03/09/23 08:35 AM
03/09/23 08:35 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I use the Mopar Performance cast ones without any issues.
Re: Stamped valve covers on TrickFlow heads? [Re: DusterKid] #3127730
03/09/23 08:48 AM
03/09/23 08:48 AM
Alabama
W
W
Alabama
Thanks for the replies, guys.
I guess I could slightly slot the sheet metal if hole alignment is off. I'll be using the '240' versions.
Re: Stamped valve covers on TrickFlow heads? [Re: WarEagle1] #3128019
03/10/23 03:29 AM
03/10/23 03:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Had some stamped chrome valve covers on the 505 with the trick flow 240 heads that I sold to Dan. I think the only issue was the valve cover gaskets needed to be trimmed for clearance around the rocker shaft stands at each end?
