Steering Wheel shift light #3126744
03/05/23 04:23 PM
03/05/23 04:23 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Not like a Fast and Furious car, but something similar. Any one do this? I would only be interested in the shift light part, not the lights that change color as RPM's get higher, but something that just flashes when you hit a pre-determined RPM.
Re: Steering Wheel shift light [Re: TheOtherDodge] #3127544
03/08/23 03:46 PM
03/08/23 03:46 PM
Houston, Texas
Houston, Texas
Guess my idea is janky... puke
Re: Steering Wheel shift light [Re: TheOtherDodge] #3127549
03/08/23 04:06 PM
03/08/23 04:06 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Functional I'm sure but may look out of place on a classic? (Assuming you have a classic)
I wired up a relay setup with an output from my efi system so the hood turn signal lights are also a shift light.
Re: Steering Wheel shift light [Re: INTMD8] #3127562
03/08/23 05:04 PM
03/08/23 05:04 PM
Houston, Texas
Houston, Texas
Not a classic... 1994 Dakota, but I like to keep the interior as "non race" as possible with out big tachs and shiftlights, sticking out everywhere, etc. Currently, my tach and shift light is mounted towards the floor and during the day, the shift light is hard to see. I want to keep it inconspicuous as possible..if possible. So looking for ideas other than the normal "shift light pen/gauge".
Re: Steering Wheel shift light [Re: TheOtherDodge] #3127566
03/08/23 05:08 PM
03/08/23 05:08 PM
an8sec70cuda Offline
Haven't seen one like that before, but I like it! I think it would look right at home in your truck. That wheel would look out of place in an old car though.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Steering Wheel shift light [Re: TheOtherDodge] #3127578
03/08/23 05:40 PM
03/08/23 05:40 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Could you use an unused dash light? Maybe a red led in the 4x4 slot? It might glow orange, but unmistakable.
Re: Steering Wheel shift light [Re: an8sec70cuda] #3127583
03/08/23 05:58 PM
03/08/23 05:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think you would be better suited to hide it in your instrument panel somewhere by taking out a warning lamp or something.
I don't know what EFI you have but I have one of these in my car and it works over the can bus and has a programable display for all kinds of things. It can also be setup as a shift light by lighting the outer ring of LEDs. It is really a pretty cool setup that doesn't take up much room and can do a variety of things. They make it for several different EFI setups.
https://store.perfecttuning.net/product/universal-gauge-for-ms3-ms3pro-ultimate-ms2-microsquirt/
68 Barracuda Formula S 340
Re: Steering Wheel shift light [Re: Bad340fish] #3127588
03/08/23 06:23 PM
03/08/23 06:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
There are more sophisticated solutions if you need to have different shift points for gear changes.
Re: Steering Wheel shift light [Re: TheOtherDodge] #3127631
03/08/23 09:00 PM
03/08/23 09:00 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Gotcha. Well one idea is looks like the bottom row of your cluster are warning lights? Maybe put a bright LED light behind an unused one (if there is one) and wire it to an rpm based output.
Re: Steering Wheel shift light [Re: CMcAllister] #3127640
03/08/23 09:17 PM
03/08/23 09:17 PM
Verrrrry South Jersey
SpeedThrills Offline
I put a shift light in one of the dash vents in one of my cars. You had to be looking for it to notice it. (when it wasn't lit grin ) Just a thought.
Re: Steering Wheel shift light [Re: SpeedThrills] #3127653
03/08/23 09:48 PM
03/08/23 09:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Needs to be hard to miss, rather than hard to see. I have had more than one guy think it wasn't working when it was. Just didn't see it.
Should hit you in the face when you are doing important things, like watching where you are going.
Re: Steering Wheel shift light [Re: CMcAllister] #3127681
03/08/23 11:26 PM
03/08/23 11:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I mounted some LEDs inside my helmet when I had my dragbike. Just remember to unplug the cord when you take it off.
Re: Steering Wheel shift light [Re: slantzilla] #3127711
03/09/23 01:25 AM
03/09/23 01:25 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Just had an idea to be more advanced stirthepot
Wire up an rpm activated output to trigger a capacitor attached to your shifting arm with an alligator clip. Super fast reaction time
Re: Steering Wheel shift light [Re: INTMD8] #3127719
03/09/23 02:57 AM
03/09/23 02:57 AM
shock tsk I have been "bit" by a charge 12V capacitor, NOT FRICKING GOOD tsk
That occurred in 10th grade auto and welding shop in 1960, The instructor had charged them up and left them on our desk tops on the first day of class, he did that as a way to teach us to not touch anything electrical in a car or anywhere else that we didn't know about or have insulated gloves on to work on that equipment shruggy
It worked up work
That would have gotten him fired and sued today or even 20 yrs. ago work shruggy
Re: Steering Wheel shift light [Re: Cab_Burge] #3127760
03/09/23 11:06 AM
03/09/23 11:06 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Haha, yes that brings back memories. In high school, 1994 the instructor would have us hold the output of a magneto and light us up cry
Re: Steering Wheel shift light [Re: INTMD8] #3127819
03/09/23 02:12 PM
03/09/23 02:12 PM
moparx Offline
moparx  Offline
charged up condensers from a points distributor bite pretty good as well.
i was "taught" that early in life. laugh2
beer
Re: Steering Wheel shift light [Re: moparx] #3127846
03/09/23 03:26 PM
03/09/23 03:26 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My Racepak dash has built in shift lights but I don't like them so I added a Pro lite like pictured above.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Steering Wheel shift light [Re: 6PKRTSE] #3128180
03/10/23 03:50 PM
03/10/23 03:50 PM
Houston, Texas
Houston, Texas
I really didn't want a shift light stuck somewhere but may have to... Dash light wont be bright enough during the day when I am watching the track! drive
Re: Steering Wheel shift light [Re: TheOtherDodge] #3128187
03/10/23 04:05 PM
03/10/23 04:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Re: Steering Wheel shift light [Re: CMcAllister] #3128213
03/10/23 05:38 PM
03/10/23 05:38 PM
Houston, Texas
Houston, Texas
[align:right][/align]
Originally Posted by CMcAllister
Tell me/show me you don't have a full on race-car with out telling me/showing me you have a full on race car! whistling
