Page 4 of 4 1 2 3 4
Re: I kind of like this Indy cross ram [Re: AndyF] #31258
10/06/06 07:05 AM
10/06/06 07:05 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Is your car ready for another 80 hp!
I'll make sure the car is ready just have to figure out if the driver is ready Soooo, see below for my current best et and then figure another 80 hp in a 3250 lb car and what et will I gain? Maybe 2.5 tenths?
Re: I kind of like this Indy cross ram [Re: max_maniac] #31259
10/06/06 08:34 AM
10/06/06 08:34 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Hey Russ - After reading Andy's results, I'm even more impressed with how well you car runs. I think my combo is pretty similar to yours, so if I can get anywhere near your best ET, I will be thrilled. Would you mind sharing your combo again? ( sorry for the hijack, Andy)
2 kids and a dog
Re: I kind of like this Indy cross ram [Re: TonyS451] #31260
10/06/06 08:55 AM
10/06/06 08:55 AM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
"I see that Indy sells a six pack lid for this intake. Anyone try that baby yet? Maybe I need to make the call to Russ and Ken and see what they think about a six pack setup on this motor. It doesn't seem like the six pack setup has enough airflow to make 700+ hp but who knows. Rossi used to make some serious power years ago with those carbs."
Has anyone ever dyno'd the Weiand sixpack tunnel ram that the Super Stockers use? I'd like to see how it compares, since the factory intake runs out of steam. I'd offer mine for a dyno run, standard size ports though.
Re: I kind of like this Indy cross ram [Re: 70BigBlockSE] #31261
10/06/06 03:02 PM
10/06/06 03:02 PM
AndyF Offline OP
AndyF  Offline OP
It looks like I'll be back on the dyno with the Indy six pack setup in the next few weeks. Won't know for sure until all the parts show up.
I don't think I'll test a std port six pack manifold since I have the MW heads. The std port setup might bolt on (not sure that the gaskets will seal) but there would be a decent size port mismatch that would put a kink in things.
Re: I kind of like this Indy cross ram [Re: Ari440] #31262
10/07/06 02:23 AM
10/07/06 02:23 AM
AndyF Offline OP
AndyF  Offline OP
ARI - You can't mount Holley carbs that have metering blocks in line but you can mount up the ones with metering plates. Here is a pic that I took with a couple of Holley 1850 carbs mounted on to the manifold. You can also turn the carbs sideways and then you could run twin HP style carbs.
It would be a real pain to tune the dual Holley setup like this though since you would have to remove the carbs to take the bowls off. And, you have to change metering plates or drill them since there isn't jets. That would get really old, especially when you're trying to sort out some cross jet issues.
One interesting data point: This combo here with the dual 1850 carbs weighs exactly 30 lbs more than a Indy 440-3 intake with a 1050 Dominator.
Re: I kind of like this Indy cross ram [Re: AndyF] #31263
10/07/06 09:39 AM
10/07/06 09:39 AM
Maryland
O
OriginalRT Offline
OriginalRT  Offline
O
Maryland
It looks as though there may be enough room left between the carbs to use a metering block in the secondaries as long as you stayed with the side hung float bowl. Just like the six pack set ups. Look at the mechanical carbs, they use a side hung float bowl and the rear fits with a metering plate. As for jetting, yah, it would suck to set it up but it's very doable.
BTW ... great photos Andy!!! you should do some side work for a magazine
Re: I kind of like this Indy cross ram [Re: AndyF] #31264
10/07/06 10:33 AM
10/07/06 10:33 AM
Idaho
Runner Offline
Runner  Offline
Idaho
andy, i believe ive seen replacement metering plats that accept jets
Re: I kind of like this Indy cross ram [Re: Runner] #31265
10/07/06 10:38 AM
10/07/06 10:38 AM
Idaho
Runner Offline
Runner  Offline
Idaho
its quick fuel part, heres the summit link. they also seell them for center hung bowls
http://store.summitracing.com/partdetail...mp;autoview=sku
Re: I kind of like this Indy cross ram [Re: OriginalRT] #31266
10/07/06 11:15 AM
10/07/06 11:15 AM
AndyF Offline OP
AndyF  Offline OP
In the picture it looks like a secondary metering block would fit on that front carb but it actually doesn't. I tried it and you would have to use a press fit to get the carbs to fit.
But, there is non particular reason why Indy couldn't spread the carbs apart by another 1/8 or 1/4 of an inch. These manifold tops are machined on a CNC vertical mill and there isn't any magic to the exact carb placement. So if a person wanted it done that way I'm sure you could work with the guys at Indy to get the carbs moved apart.
Re: I kind of like this Indy cross ram [Re: AndyF] #31267
10/07/06 08:29 PM
10/07/06 08:29 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
So did the Indy Intake really make 80 more horses over the new Mopar Crossram?????????
Re: I kind of like this Indy cross ram [Re: nss guy] #31268
10/10/06 12:55 PM
10/10/06 12:55 PM
AndyF Offline OP
AndyF  Offline OP
Yes, that is basically correct.
Page 4 of 4 1 2 3 4
