A body bigblock 402 pan #312610
05/09/09 12:41 PM
05/09/09 12:41 PM
IL.
bcudaj380 Offline OP
IL.
Will the idler and pitman arms clear
the 402 oilpan in an A body big block?
Re: A body bigblock 402 pan [Re: bcudaj380] #312611
05/09/09 12:46 PM
05/09/09 12:46 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I think it will hit a 402, I can't remember the number that works but someone will reply that does.
Re: A body bigblock 402 pan [Re: bcudaj380] #312612
05/09/09 12:48 PM
05/09/09 12:48 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No it's going to hit , cheapest A body conversion pan is the c barge 187 pan but it has no baffles , which you can add.
Re: A body bigblock 402 pan [Re: bcudaj380] #312613
05/10/09 08:22 PM
05/10/09 08:22 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Re: A body bigblock 402 pan [Re: bcudaj380] #312614
05/10/09 08:25 PM
05/10/09 08:25 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
402 vs. 187...
Re: A body bigblock 402 pan [Re: OzHemi] #312615
05/11/09 09:28 AM
05/11/09 09:28 AM
JohnRR Offline
JohnRR  Offline
402 vs. 187...
that 402 looks oddly FAMILIAR ...
Re: A body bigblock 402 pan [Re: JohnRR] #312616
05/11/09 11:20 AM
05/11/09 11:20 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I sold it to some guy, who was way in the deep dark territory...
Re: A body bigblock 402 pan [Re: OzHemi] #312617
05/11/09 07:12 PM
05/11/09 07:12 PM
IL.
IL.
Thanks guys I already have a 187 pan,
looks like I will have to cut it and add
an inch. Probably will not gain much in
oil capacity but won't drag the ground.
Re: A body bigblock 402 pan [Re: bcudaj380] #312618
05/12/09 09:38 AM
05/12/09 09:38 AM
JohnRR Offline
JohnRR  Offline
The 187 holds the same amount of oil as the 402 pan .
Re: A body bigblock 402 pan [Re: JohnRR] #312619
05/12/09 07:00 PM
05/12/09 07:00 PM
IL.
IL.
Thanks for the info John I thought
the 402 pan held 5 qts. and the 187
held 4 qts.
