Re: Another 80s truck question
[Re: volaredon]
#3124103
02/23/23 08:41 PM
02/23/23 08:41 PM
Posts: 284 Bennett, Colorado
Charger69RT8
Bennett, Colorado
I can't say for sure but I think likely so. This is based on my 1978, that I swapped a 727 for a 833 from a b-body. I did not have to modify the drive shaft. I believe the 833 and the 833OD are the same length.
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
[Re: volaredon]
#3124149
02/24/23 12:11 AM
02/24/23 12:11 AM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
As long as both the 727 and the 833OD are the short tail shaft or both are the long tail shaft, they should use the same drive shaft. If one is a short tail shaft, and the other is a long tail shaft, you will need a different drive shaft.
Both the 833 and the 833 OD have short tail shaft and long tail shaft versions, the drive shaft length would depend on which tail shaft the trans has. If both are the same version, the drive shaft is the same, but if one is a short tail shaft and the other is a long tail shaft, you need a different drive shaft. So: For a 727, an 833 or an 833OD mix and match: Short / short = same DS Long / long = same DS Short / long = different DS
[Re: volaredon]
#3124478
02/25/23 12:10 PM
02/25/23 12:10 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
Considering a swap from 727 to 833OD. 85 long bed 2wd. 8-1/4 rear. Is the driveshaft the same length between these two transmissions? Since the transmissions are the same length from the trans mount to the end of the tailshaft it would be the same driveshaft.
