Another 80s truck question #3124093
02/23/23 07:34 PM
02/23/23 07:34 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
Considering a swap from 727 to 833OD. 85 long bed 2wd. 8-1/4 rear. Is the driveshaft the same length between these two transmissions?
Re: Another 80s truck question [Re: volaredon] #3124103
02/23/23 08:41 PM
02/23/23 08:41 PM
Bennett, Colorado
Charger69RT8 Offline
Bennett, Colorado
I can't say for sure but I think likely so. This is based on my 1978, that I swapped a 727 for a 833 from a b-body. I did not have to modify the drive shaft. I believe the 833 and the 833OD are the same length.
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: Another 80s truck question [Re: Charger69RT8] #3124119
02/23/23 09:25 PM
02/23/23 09:25 PM
ILLINOIS
V
V
ILLINOIS
This is a truck 833 OD. Same length as a b body 833
I did an 833 od swap into a truck one other time, 30 years ago.
That was a 79 short bed and I used the trans I had in hand at the time which was a short tail version out of an F body.
On THAT One I did have to get a different driveshaft, and I found one with only having to use a tape measure at a driveshaft [censored] at a junkyard, something not often seen in this day of front (wrong) wheel drive vehicles......
Re: Another 80s truck question [Re: volaredon] #3124149
02/24/23 12:11 AM
02/24/23 12:11 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As long as both the 727 and the 833OD are the short tail shaft or both are the long tail shaft, they should use the same drive shaft. If one is a short tail shaft, and the other is a long tail shaft, you will need a different drive shaft.
Both the 833 and the 833 OD have short tail shaft and long tail shaft versions, the drive shaft length would depend on which tail shaft the trans has. If both are the same version, the drive shaft is the same, but if one is a short tail shaft and the other is a long tail shaft, you need a different drive shaft.
So:
For a 727, an 833 or an 833OD mix and match:
Short / short = same DS
Long / long = same DS
Short / long = different DS
Re: Another 80s truck question [Re: poorboy] #3124198
02/24/23 11:43 AM
02/24/23 11:43 AM
ILLINOIS
V
V
ILLINOIS
Both I have are long tail for this one
Re: Another 80s truck question [Re: volaredon] #3124478
02/25/23 12:10 PM
02/25/23 12:10 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Since the transmissions are the same length from the trans mount to the end of the tailshaft it would be the same driveshaft.
Re: Another 80s truck question [Re: JohnRR] #3124568
02/25/23 04:36 PM
02/25/23 04:36 PM
ILLINOIS
V
V
ILLINOIS
Ok cool, one less headache to worry about
