Page 3 of 4 1 2 3 4
Re: I kind of like this Indy cross ram [Re: AndyF] #31238
10/01/06 12:46 AM
10/01/06 12:46 AM
Andy, I know you said that the carb. you got is one of the new Ultra Dominators but you might wnat to look at(if it has them)the power valve fuel holes in the metering block. I bought a 8896-1 several years ago and it had humongous PVRC in the metering plates, to big to be able to jet the carb down enough to get a good AFR reading at WOT with out making the motor detaonate at part throttle. The Carb. Shop was next door to the dyno shop and they fix the metering plates so we could still run the front power valve and block the rear one off, that made the jetting a lot easier to tune.
Re: I kind of like this Indy cross ram [Re: AndyF] #31239
10/01/06 02:10 AM
10/01/06 02:10 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The LM1 is one of the greatest tuning tools ever. One of my next projects is to use the LM1 on my car and see if I can actually dial in a Holley Dominator so that it works on the street. I'm not sure if I can get it to a point where it drives super nice but I figured it would be a fun thing to mess with.
Andy, and this is what impressed me most about 1FastMopar's car during Drag Week! i asked the questions but Eddie wouldn't answer. i saw some things that were very interesting
we all know that a dominator will make the numbers, the multi carb setups are for those that want to be different
Re: I kind of like this Indy cross ram [Re: AndyF] #31240
10/01/06 08:07 AM
10/01/06 08:07 AM
Andy, going from the oe maxwedge to the indy intake,
what metering jets and metering rods did you use on your oe max wedge intake
and what metering jets and metering rods on the indy 440-25 intake.
my oe crossram uses 113 primarys
110 secondaries
need some recommendations on jetting the indy intake
Re: I kind of like this Indy cross ram #31241
10/01/06 12:08 PM
10/01/06 12:08 PM
AndyF Offline OP
AndyF  Offline OP
The carbs are the #1812 Edelbrock 800 cfm AVS units. We had them box stock on the MP cross ram. 113 jets, 68/47 rods and 101 jets. On the cross ram they were a little rich, AF was 11.9 during the pulls. But we didn't lean it out since a couple of cylinders were up in the 1350 temp range while others were down around 1100 degrees. So it needed to be tweaked but we didn't want to spend the time dialing it in.
On the Indy x box the carbs were way lean. We jetted it up to 104 on the secondaries but it was still lean. It could've gone 107 or maybe even 110. There was still some cylinder to cylinder variation but not as much.
The Indy manifold doesn't come with any gaskets anywhere so my guess is that it is full of vacuum leaks. We tried to seal it up with RTV which is okay for some dyno pulls but that wouldn't last long on a real engine. That manifold really needs to be redesigned so that it has o-rings seals internally and on the tops. Some good viton covered washers under the intake to head bolts would also be a good idea. That way you won't have gas leaking down in to the oil pan.
Re: I kind of like this Indy cross ram [Re: AndyF] #31242
10/01/06 05:08 PM
10/01/06 05:08 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Not at all suprised you got more HP out of the new Indy inline Xram than the one patterned after the old original Max Xram, I can run right at 2 tenths quicker with a Dominator and Indy single plane than with the Xram, normally on the Xram you need to richen up the throttle sides of the carbs a bit to get a more equal distribution. The old Crossrams aren't the fastest, but the look can't be beat.
Re: I kind of like this Indy cross ram [Re: Michael] #31243
10/01/06 06:58 PM
10/01/06 06:58 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I remember 3 or 4 years ago when Indy came out with that manifold, a friend of mine installed that intake on his Max Wedge and picked up over a half a second over the OEM cross-ram. That manifold will make power!
That seems like it would not be possible but next year I may just find out for sure. Currently I'm running on OE max wedge intake and was thinking of going to the Mopar x ram or the Indy. I think this test Andy just did made up my mind. As of right now with an original x ram I have a best of 10.07 but in the heat it stays in the 10.10 to 10.15 range. I think the Indy intake would put me in the ball park for some high 9.90's in the heat which would be right on for the 10.0 class. Thanks Andy for doing the testing and posting the results. I currently have the 750 carbs and will start with them next year but may go to the 800's if needed.
Re: I kind of like this Indy cross ram [Re: max_maniac] #31244
10/01/06 08:07 PM
10/01/06 08:07 PM
I GOT .4-.5 OUT OF THE BOX ON MY INDY 440-25 INTAKE COMPARED TO MY ORIGINAL MAX WEDGE CROSSRAM.
I WENT FROM 10.70 TO 10.30 RIGHT OUT OF THE BOX AND THEN JETTED AND GOT ANOTHER TENTH OUT OF IT. YOU NEED SOME BIG METERING JETS FOR THIS INDY INTAKE.
I THINK IT IS ONE UGLY PIECE BUT IT WORKS FOR SURE.
SO YOU NEED TO KNOW: "WOULD YOU RATHER LOOK GOOD OR RUN GOOD" THAT IS THE QUESTION?
Re: I kind of like this Indy cross ram #31245
10/01/06 08:12 PM
10/01/06 08:12 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
how tall is the indy crossram?
how much do they go for?
1.39 9.85 - 137 mph
Re: I kind of like this Indy cross ram [Re: Ari440] #31246
10/01/06 08:19 PM
10/01/06 08:19 PM
i know they go for $1250.00 retail but call FAST68PLYMOUTH, i think He has a real good price on them
Re: I kind of like this Indy cross ram [Re: max_maniac] #31247
10/02/06 02:09 AM
10/02/06 02:09 AM
AndyF Offline OP
AndyF  Offline OP
If you pick up 75 hp like we did on this motor then you should easily pick up a couple of tenths if not more. It will depend on how much power capability the motor has. This was a flat tappet motor that were shutting off around 6500 rpm. If it was a roller motor that was turning 7500 rpm I bet the HP difference would have been even greater.
Switching from the cross ram to the X box will add some power but you'll probably need to change gears and maybe upgrade the valvetrain to take advantage of the new power.
I'd think the 750 carbs would work fine on the X box. I ran 800's since that is what I had but I can't see why the 750's wouldn't work just as well.
The biggest problem is getting the tune up correct. It is kind of a pain to deal with twin Eddy carbs! It is a lot of little clips, levers, springs, rods, etc everytime you pull the tops. I can see where a guy would get tired of twisting screws if you had to do a bunch of trial and error to get the cross jetting correct. At some point I'd put studs in the top of the Eddy carbs just to keep from stripping out those screws.
Re: I kind of like this Indy cross ram [Re: Ari440] #31248
10/04/06 10:54 AM
10/04/06 10:54 AM
AndyF Offline OP
AndyF  Offline OP
Ari - here is the throttle bracket that I designed for this setup. I talked to Indy about supplying it to them so if that deal works out then people will be able to buy a turn key setup from them.
Re: I kind of like this Indy cross ram [Re: AndyF] #31249
10/04/06 11:30 AM
10/04/06 11:30 AM
Maryland
O
OriginalRT Offline
OriginalRT  Offline
O
Maryland
Numbers? results? wha-da-we got?
Re: I kind of like this Indy cross ram [Re: OriginalRT] #31250
10/04/06 12:13 PM
10/04/06 12:13 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Andy, just send me both of the intake set ups you tried with the carbs and I'll stick em on mine and do some REAL track testing and they can be compared to my oe x ram
Re: I kind of like this Indy cross ram [Re: max_maniac] #31251
10/04/06 01:00 PM
10/04/06 01:00 PM
AndyF Offline OP
AndyF  Offline OP
Is your car ready for another 80 hp!
I see that Indy sells a six pack lid for this intake. Anyone try that baby yet? Maybe I need to make the call to Russ and Ken and see what they think about a six pack setup on this motor. It doesn't seem like the six pack setup has enough airflow to make 700+ hp but who knows. Rossi used to make some serious power years ago with those carbs.
Re: I kind of like this Indy cross ram [Re: AndyF] #31252
10/04/06 04:13 PM
10/04/06 04:13 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
3 4412 500 CFM CARBS with the air horns cut down and the power valves blocked in the outboards is the route i would take. it would save several hundred dollars over six pack carbs
Re: I kind of like this Indy cross ram [Re: sixpackgut] #31253
10/04/06 09:35 PM
10/04/06 09:35 PM
ANDY, WHATS THE PRICE FOR THE THROTTLE BRACKET AND LINKAGE RODS, I HAVE THE OFFSET TOP.
I LIKE WHAT I SEE.
Re: I kind of like this Indy cross ram #31254
10/04/06 10:05 PM
10/04/06 10:05 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
how tall is the indy crossram ?
to mount two HOLLEY 750,s what linkiage whould you use ?
can you mount the 750s holley inline ?
1.39 9.85 - 137 mph
Re: I kind of like this Indy cross ram #31255
10/05/06 12:42 AM
10/05/06 12:42 AM
AndyF Offline OP
AndyF  Offline OP
I haven't set prices yet for this stuff since I haven't finished designing the kits yet.
How far offset are your carbs? I don't think I've seen an offset top. If they aren't offset very far maybe the heim joints would take up the angle. Othwise you would need a linkage with a jog in it.
Re: I kind of like this Indy cross ram [Re: AndyF] #31256
10/05/06 07:31 AM
10/05/06 07:31 AM
Ohio
john55 Offline
john55  Offline
Ohio
that six pack set up sounds neat, any chance it would fit under a stock air grabber hood? it looks kinda tall to go under a stock hood.....
The Plymouth Win You Over Beat Goes On
Re: I kind of like this Indy cross ram [Re: john55] #31257
10/05/06 07:45 PM
10/05/06 07:45 PM
ANDY,indy has a small offset top which is offset around 2" staggered, i've seen a intake with a jogged linkage rod, i made up a straight rod(not professionally done) waiting for your parts,with oe carb swivel ends, i think a small jogged linkage rod would work fine, pm me with a price on the throttle bracket, and linkage rod, i'll buy it immediately thanks, also i need one of those indy 2 piece valley covers machined so you can slip it under the heads so you dont have to remove the heads.
Page 3 of 4 1 2 3 4
