Cowl dents #3123791
02/22/23 07:34 PM
02/22/23 07:34 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I almost smoothed these out on my 69 gtx, then Remembered seeing them on other cars.
I went fishing for a12s since they were only built in one plant/same plant as my gtx, and I’m finding
Them all dented.
So….is it a lynch road thing, or did other plants do it?
Side note, the glob of seam sealer on the pinch weld never made sense to me until I ground it off…
91184A72-48B2-4ED1-813C-B93034DA9CC3.jpeg0F061FEC-0603-49C1-81A1-A20DC1DE83FB.jpeg9FE8A023-3D19-42CC-88BD-55B0C86D916F.jpeg2BD37A15-4170-4ADE-963B-423CD8F6A657.jpeg
Rich H.
Esse Quam Videri
Re: Cowl dents [Re: ZIPPY] #3123869
02/22/23 11:44 PM
02/22/23 11:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Other assembly plants also had the cowl dents. There was a few page thread over on the A12 Registry/playground site about this. I'll see if I can find the thread. My '69 GTX "E" LA assembly plant has them along with a friend's (local) '69 LA plant Road Runner too. I'll post photos of both.
Re: Cowl dents [Re: A12] #3123879
02/23/23 12:13 AM
02/23/23 12:13 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's the A12 link hope it works, http://a12mopar.com/yabb/YaBB.pl?num=1439982965/0
Re: Cowl dents [Re: A12] #3123880
02/23/23 12:15 AM
02/23/23 12:15 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Personally I think this is how and where those "dimples" are made, but you know what they say about opinions. blush wink
Re: Cowl dents [Re: A12] #3123913
02/23/23 09:56 AM
02/23/23 09:56 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Perfect, thanks.
Been looking at that for a long time on a lot of cars, that is for sure.
Can't open the link without registering.......Site registration doesn't work, I probably have nothing of value to contribute and I really don't want to dink around with emailing the admin to get in, so
will be satisfied with this tiny bit of research. Appreciate the comments!
Rich H.
Esse Quam Videri
Re: Cowl dents [Re: ZIPPY] #3123931
02/23/23 11:36 AM
02/23/23 11:36 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe they whacked the upper cowl panels with a hammer to seat it before/during welding ?
Re: Cowl dents [Re: topside] #3123949
02/23/23 12:26 PM
02/23/23 12:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
IMO I don't think so as they always seem to be consistent in spacing, location and depth. Some examples even look like they were done by the weight of the Body in White (BIW) chassis like the car going into the dip tank. But again just an opinion and a discussion point that's been kicked around.
Re: Cowl dents [Re: A12] #3124091
02/23/23 07:30 PM
02/23/23 07:30 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Its on some thread that I read but can’t remember where. Those dents were done at the lynch road plant. One dent was first shift and two dents was second shift on the welding line
Re: Cowl dents [Re: A12] #3124700
02/26/23 07:40 AM
02/26/23 07:40 AM
MN
Droop69 Offline
Droop69  Offline
MN
From what I have seen on the dents they seem very consistent in location and depth. I think A12 is correct, it was from the rigging when the body went through the dip tank.
Re: Cowl dents [Re: Droop69] #3124703
02/26/23 08:32 AM
02/26/23 08:32 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve got two Lynch road cars and both only have one dent per side not the two in the last picture. And they are not as deep.
Re: Cowl dents [Re: fastmark] #3124884
02/26/23 08:30 PM
02/26/23 08:30 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Mine has one dent per side also, in the same location of the pics I posted.
It’s an interesting factory flaw that I’ll leave alone, knowing it’s normal.
Rich H.
Esse Quam Videri
Re: Cowl dents [Re: ZIPPY] #3124967
02/27/23 08:54 AM
02/27/23 08:54 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
No dents here
1969 Hemi Roadrunner 2nd owner
Re: Cowl dents [Re: 69hemibeep] #3125306
02/28/23 02:16 PM
02/28/23 02:16 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Some must have got away unscathed.
Rich H.
Esse Quam Videri
Re: Cowl dents [Re: ZIPPY] #3125416
02/28/23 07:20 PM
02/28/23 07:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I can't believe I missed one... hammer
JB Rhinehart, Realist
A-Body's RULE!
