Page 1 of 5 1 2 3 4 5
Distributor phasing is a good idea #312375
05/09/09 07:10 AM
05/09/09 07:10 AM
Answering the call of the wild
ThermoQuad Offline OP
I wanted to share the lack of wear on my cap terminals and rotor from the phased MP distributor in my hot rod. 15,000 miles
The primary benefit of a phased distributor is the car runs wayyyy better
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312376
05/09/09 07:12 AM
05/09/09 07:12 AM
rotor
Most Mopar distributors require phasing and it is simple to check and correct
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312377
05/09/09 07:41 AM
05/09/09 07:41 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
rotor
PLEASE Tell !!!!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Distributor phasing is a good idea [Re: Dartsport540] #312378
05/09/09 08:17 AM
05/09/09 08:17 AM
scratchnfotraction Offline
what is this new snake oil thing u speak of?
Re: Distributor phasing is a good idea [Re: scratchnfotraction] #312379
05/09/09 08:57 AM
05/09/09 08:57 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Yes,, do tell all
Re: Distributor phasing is a good idea [Re: scratchnfotraction] #312380
05/09/09 08:58 AM
05/09/09 08:58 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312381
05/09/09 09:38 AM
05/09/09 09:38 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
rotor
Go ahead and post your technique, You wouldn't want to draw a delay of game penalty here now would you?
Re: Distributor phasing is a good idea [Re: scratchnfotraction] #312382
05/09/09 10:01 AM
05/09/09 10:01 AM
BDW Offline
BDW  Offline
Re: Distributor phasing is a good idea [Re: BDW] #312383
05/09/09 10:37 AM
05/09/09 10:37 AM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Somewhere I read an article on how to do it yourself, but don't know where it was.
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312384
05/09/09 12:11 PM
05/09/09 12:11 PM
rotor
I've found that words like always, all, none, and never, as well as "most" can really get a person into trouble.
So what you're saying is, if we were to go back in time, and gather up "most" Mopar distributors, made from, say, 62-78 or thereabouts, that MOST of them, as in, "damn near all" would be seriously out of phase, so much out of phase that they just absolutely REQUIRE the owner to replace the cap and rotor every, what? week? month? and the "magic cure" I'd guess, is to send it to YOU the absolute authority, the one guy who has a distributor machine, the ONE guy who has the mojo? Now, I'm simply thinking out loud here, to be clear, that is, so, do "we" have it right?
Re: Distributor phasing is a good idea [Re: redraptor] #312385
05/09/09 01:20 PM
05/09/09 01:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312386
05/09/09 01:46 PM
05/09/09 01:46 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Hey Tom how big of a hole did you drill in the cap and those look like blue streak.
Re: Distributor phasing is a good idea [Re: JohnRR] #312387
05/09/09 01:48 PM
05/09/09 01:48 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
Oh boy...
Until total honesty is on the table, we're not even talking about reality...
Re: Distributor phasing is a good idea [Re: Iceman01] #312388
05/09/09 02:52 PM
05/09/09 02:52 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
hmmm...interesting stuff!
**Photobucket sucks**
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312389
05/09/09 04:28 PM
05/09/09 04:28 PM
AndyF Online content
AndyF  Online Content
I used to sell these reluctors that were modified with extra slots so the distributor could be phased. That trick worked really well for me back when I was running factory distributors.
These days I run a Jesel distributor and all I need to phase it is to just loosen up the mounting bolts and rotate it into position.
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312390
05/09/09 04:42 PM
05/09/09 04:42 PM
Virginia
JimG Offline
JimG  Offline
Virginia
After finding out that AndyF was sold out of reluctors, I corrected the phasing on mine by filing the locating slot on the distributor cap wider then filling the other side of the slot with JB Weld, thereby rotating the distributor cap on the distributor.
Yeah, it's ghetto, but it works until I can fix it right...however that may be.
Mine wasn't too far out of phase. I'm sure there are limits on how much correction is possible using my method. Eventually, the holddown straps would have nothing to grab on to.
Re: Distributor phasing is a good idea [Re: JimG] #312391
05/09/09 08:41 PM
05/09/09 08:41 PM
so what exactly is the skinny here?
I missed sumthin
what are we fasing?
the reluctor on the dist?
please skool me,would it be the same on a points dist or elect only
what do you look for when see if its off?
how does it get corrected?
just wondering myself,I allways thought indexing the spark plugs was snake oil till I did it
now if I could only remember what direction the electrode on the plug is "supposed" to face
Re: Distributor phasing is a good idea [Re: scratchnfotraction] #312392
05/09/09 09:07 PM
05/09/09 09:07 PM
Virginia
JimG Offline
JimG  Offline
Virginia
In the case of an electronic, when one of the "fins" on the reluctor is aligned with the pickup (and hence, the ignition is firing), the rotor should be aligned with a terminal on the distributor cap. If not, spark has to jump from the rotor to the terminal every time the ignition fires.
To test, you take an old distributor cap and drill a big hole in the top between the center terminal and the #1 spark plug terminal so you can see inside. Install this cap on your engine. Take a timing light, connected to #1 and use the strobe effect to see if the rotor is aligned with #1 terminal when #1 spark plug is firing. If so, great, you're done. If not you have a phasing problem.
Re: Distributor phasing is a good idea [Re: JimG] #312393
05/09/09 09:16 PM
05/09/09 09:16 PM
OOOHHH!!!!
I think I gots it now
this hole in the cap...dont they drill a couple holes around the cap to stop the miss fireing from the ionazation(sp?) build up or something like that?
thats what I was stuck on
your talking drilling a hole and checking alinement of the rotor and term...
after going and looking at the old dist<i guess you cant remove the rub block for the points were the reluctor would be...DOH!!
Re: Distributor phasing is a good idea [Re: JimG] #312394
05/10/09 07:09 AM
05/10/09 07:09 AM
BDW Offline
BDW  Offline
Good explanation, what do you do to adjust an electronic distributor if needed? If filing is not enough.
