tig welding #3123533
02/21/23 10:33 PM
02/21/23 10:33 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Do you need to unhook all MSD AND. DIGITAL CONTROL AND GROUNDS WHEN tigwelding ? Thanks
Re: tig welding [Re: dragon] #3123558
02/21/23 11:49 PM
02/21/23 11:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I just unplugged my Msd, tach, & battery. Don’t need any issues, stuffs too expensive anymore.
Re: tig welding [Re: dragon] #3123579
02/22/23 02:05 AM
02/22/23 02:05 AM
Cab_Burge Online work
Cab_Burge  Online Work
Way better to be safe than wish you had been safe later work grin
now get to wrench before weld up
Re: tig welding [Re: dragon] #3123599
02/22/23 09:03 AM
02/22/23 09:03 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I usually isolate the batteries with the cut off switch and unplug the MSD, Racepak and Dig Dash stuff. I've welded on the car more than once when I've forgotten to unplug things and never had an issue. Does it matter ? or have I dodged a bullet ? Like Cab and Rick says, I'd rather play safe and disconnect and / or remove stuff like SD cards
Re: tig welding [Re: dragon] #3123666
02/22/23 01:24 PM
02/22/23 01:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Yes
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: tig welding [Re: W.I.N. Racing] #3123671
02/22/23 01:36 PM
02/22/23 01:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
YES!
Re: tig welding [Re: Al_Alguire] #3123689
02/22/23 02:31 PM
02/22/23 02:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Turn off the hearing aids too, remember the static on the AM radios with solid core plug wires, same idea
Re: tig welding [Re: cudaman1969] #3123781
02/22/23 07:24 PM
02/22/23 07:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes. And pay attention to where you hook the ground. You can damage stuff by putting the clamp in the wrong place.
Re: tig welding [Re: CMcAllister] #3123783
02/22/23 07:25 PM
02/22/23 07:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
And disconnect your pacemaker
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
