Re: tig welding
[Re: dragon]
#3123599
02/22/23 09:03 AM
02/22/23 09:03 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I usually isolate the batteries with the cut off switch and unplug the MSD, Racepak and Dig Dash stuff. I've welded on the car more than once when I've forgotten to unplug things and never had an issue. Does it matter ? or have I dodged a bullet ? Like Cab and Rick says, I'd rather play safe and disconnect and / or remove stuff like SD cards .
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: tig welding
[Re: dragon]
#3123666
02/22/23 01:24 PM
02/22/23 01:24 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
Do you need to unhook all MSD AND. DIGITAL CONTROL AND GROUNDS WHEN tigwelding ? Thanks Yes
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: tig welding
[Re: Al_Alguire]
#3123689
02/22/23 02:31 PM
02/22/23 02:31 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
Turn off the hearing aids too, remember the static on the AM radios with solid core plug wires, same idea
Re: tig welding
[Re: cudaman1969]
#3123781
02/22/23 07:24 PM
02/22/23 07:24 PM
Posts: 11,714 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yes. And pay attention to where you hook the ground. You can damage stuff by putting the clamp in the wrong place.
Re: tig welding
[Re: CMcAllister]
#3123783
02/22/23 07:25 PM
02/22/23 07:25 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
And disconnect your pacemaker
