Re: 80s truck question
[Re: volaredon]
#3123581
02/22/23 06:45 AM
02/22/23 06:45 AM
Posts: 5,886 ohio
ruderunner
ohio
No. The only optional tach I'm aware of was in the diesel trucks and was an add on pod.
Angry white pureblood male
[Re: volaredon]
#3123695
02/22/23 03:08 PM
02/22/23 03:08 PM
Posts: 10,589 Freeport IL USA
poorboy
Freeport IL USA
That's what i thought too, truck in question is earlier 80s than could be had w/a diesel, and I have the dash completely out of it so I can add everything that a factory AC truck would have had that's different than a non AC truck, so I thought now would be the best time find one if it existed so I only have to dismantle things once. I see you too are getting lazy more efficient in your old age.
[Re: volaredon]
#3124012
02/23/23 03:24 PM
02/23/23 03:24 PM
Posts: 738 Middle TN.
4x4 Roundup
Middle TN.
This is the factory tach for a '79. I think it was available at least as late as 1980.
WANTED-- DEAD or ALIVE: '70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car. '79 Power Wagon W14JE9S137761 or 763
[Re: 4x4 Roundup]
#3124098
02/23/23 08:07 PM
02/23/23 08:07 PM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
This is the factory tach for a '79. I think it was available at least as late as 1980. Yes. It was optional but could be substituted with a clock and came with the volt and vaccum guages that went in the same spot on the opposite side of the dash. The dash changed with the rest in 81.
