Leak Down Test- Whats Acceptable #312344
05/08/09 11:55 PM
05/08/09 11:55 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
What do you guys think is acceptable leakage when running a leak down test?
I've also had people tell me its fine to do it cold. Im not so sure I believe that. Whats the general opinion on that?
Re: Leak Down Test- Whats Acceptable [Re: GTX MATT] #312345
05/09/09 09:50 AM
05/09/09 09:50 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Depends on what the car was built for. Street is
much different than track. I'd do it warm. If I
remember correctly, I think the cutoff point for
street max was 12% variation.
Re: Leak Down Test- Whats Acceptable [Re: Dart 340] #312346
05/09/09 12:19 PM
05/09/09 12:19 PM
Az
Crizila Offline
Crizila  Offline
Az
From what I can remember, it was a woopping 20% for street engines.
Fastest 300
Re: Leak Down Test- Whats Acceptable [Re: Crizila] #312347
05/09/09 02:30 PM
05/09/09 02:30 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
No kidding, wow I didn't think it was that much.
Then again, I have only done a couple of these so I
am far from an expert.
Re: Leak Down Test- Whats Acceptable [Re: Dart 340] #312348
05/09/09 02:39 PM
05/09/09 02:39 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm sure things have changed, but I believe that was a Ford spec from around 1979 80. Max acceptable varation between cylinders. You basically have to decide what is acceptable for you and your intended use. There really is no "correct" #.
Fastest 300
Re: Leak Down Test- Whats Acceptable [Re: Crizila] #312349
05/09/09 06:36 PM
05/09/09 06:36 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Anything beyond 15% to me is suspect, unless it's a high milage engine. Fresh engine with std type rings seated on the right bore finish will be between 5-8%, zero gap or gapless type rings should be less than 3%. Is that the 383?
Re: Leak Down Test- Whats Acceptable [Re: moper] #312350
05/09/09 06:37 PM
05/09/09 06:37 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
And BTW, should be done hot.
