Leak Down Test- Whats Acceptable
#312344
05/08/09 11:55 PM
05/08/09 11:55 PM
Posts: 5,161 CT
GTX MATT
CT
What do you guys think is acceptable leakage when running a leak down test?
I've also had people tell me its fine to do it cold. Im not so sure I believe that. Whats the general opinion on that?
Re: Leak Down Test- Whats Acceptable
[Re: Dart 340]
#312346
05/09/09 12:19 PM
05/09/09 12:19 PM
Posts: 7,506 Az
Crizila
Az
From what I can remember, it was a woopping 20% for street engines.
Fastest 300
[Re: Dart 340]
#312348
05/09/09 02:39 PM
05/09/09 02:39 PM
Posts: 7,506 Az
Crizila
Az
I'm sure things have changed, but I believe that was a Ford spec from around 1979 80. Max acceptable varation between cylinders. You basically have to decide what is acceptable for you and your intended use. There really is no "correct" #.
Fastest 300
[Re: Crizila]
#312349
05/09/09 06:36 PM
05/09/09 06:36 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Anything beyond 15% to me is suspect, unless it's a high milage engine. Fresh engine with std type rings seated on the right bore finish will be between 5-8%, zero gap or gapless type rings should be less than 3%. Is that the 383?
[Re: moper]
#312350
05/09/09 06:37 PM
05/09/09 06:37 PM
moper
Columbia, CT
And BTW, should be done hot.
