plastic engine blocks #3122682
02/18/23 10:28 PM
02/18/23 10:28 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Does anyone know where to find the plastic engine blocks used for mock up? I need a Hemi style engine so i can see what i will need to fabricate to fit my 572 .
Re: plastic engine blocks [Re: mopar dave] #3122685
02/18/23 11:03 PM
02/18/23 11:03 PM
Mt Morris Michigan
Mt Morris Michigan
found something at summit. Are they any other companies making these?
Re: plastic engine blocks [Re: mopar dave] #3122698
02/18/23 11:58 PM
02/18/23 11:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
We got ours from Summit in 2018. It worked well. Served its purpose. Now it's in the way 🤣
Re: plastic engine blocks [Re: Hot 340] #3122714
02/19/23 01:05 AM
02/19/23 01:05 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just use an old KB aluminum Hemi block I have with no sleeves. Weighs almost nothing. I lift in and out of the engine bays all the time by hand.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: plastic engine blocks [Re: 6PKRTSE] #3122717
02/19/23 01:26 AM
02/19/23 01:26 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
In my experience, the plastic replicas with threaded inserts are too flimsy to be used as a fixture for building parts and mounts.
Re: plastic engine blocks [Re: CMcAllister] #3122783
02/19/23 12:18 PM
02/19/23 12:18 PM
Mt Morris Michigan
Mt Morris Michigan
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance.
Re: plastic engine blocks [Re: mopar dave] #3122805
02/19/23 01:02 PM
02/19/23 01:02 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
Mike Roth at MR2 racecars sells a offset m/c adapter and the pedal mod piece that cleared my KB valve covered Hemi in my 68 Barracuda. Lamb has one but won't sell it unless you buy their brakes to go with it! Old DC piece wasn't close with the cast covers.
Re: plastic engine blocks [Re: Handygun] #3122833
02/19/23 02:31 PM
02/19/23 02:31 PM
Mt Morris Michigan
Mt Morris Michigan
thank you for that heads up. what mods did you do the the inner fender to get the cover to clear?
Re: plastic engine blocks [Re: mopar dave] #3122834
02/19/23 02:32 PM
02/19/23 02:32 PM
A727Tflite Offline
A727Tflite  Offline
Why can’t you just lay the Hemi heads on a 440.
Re: plastic engine blocks [Re: A727Tflite] #3122838
02/19/23 02:44 PM
02/19/23 02:44 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Wow, I never knew
http://mockupmotors.com
For these prices I'd carve one out of pine
https://www.speedwaymotors.com/shop/mock-up-engine-blocks~14-18-542-18045
Re: plastic engine blocks [Re: Ray S] #3122887
02/19/23 06:14 PM
02/19/23 06:14 PM
Mt Morris Michigan
Mt Morris Michigan
I believe this is the brand summit has.
Re: plastic engine blocks [Re: Ray S] #3122917
02/19/23 08:23 PM
02/19/23 08:23 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by Ray S
Wow, I never knew
If she comes with it, I'M IN!
Re: plastic engine blocks [Re: mopar dave] #3122926
02/19/23 08:46 PM
02/19/23 08:46 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
[quote=mopar dave] thank you for that heads up. what mods did you do the the innIer fender to get the cover to clear? PM me.
Re: plastic engine blocks [Re: Ray S] #3122994
02/20/23 07:46 AM
02/20/23 07:46 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
And they don't list a 400 cu" block but they do list a 318 frown
Re: plastic engine blocks [Re: mopar dave] #3122995
02/20/23 07:50 AM
02/20/23 07:50 AM
NY
B1duster Offline
B1duster  Offline
NY
I have one I’d let you borrow but I’m in NY.
Hopefully someone close by chimes in.
I also remember reading the sizing was off, a little narrow
Re: plastic engine blocks [Re: B1duster] #3123091
02/20/23 03:10 PM
02/20/23 03:10 PM
moparx Offline
moparx  Offline
makes one want to get a junk block and transmission case, then hack out most of the internal structure to lighten it up some.
beer
Re: plastic engine blocks [Re: moparx] #3123114
02/20/23 04:38 PM
02/20/23 04:38 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
??? FOR THOSE PRICES>????
Sorry but im a cheap M fer.....i would ask around for a blown up engine before i paid 400+ for a mock up block
....BAD A$$ STREET CAR.....
Re: plastic engine blocks [Re: n20mstr] #3123301
02/21/23 10:57 AM
02/21/23 10:57 AM
Mt Morris Michigan
Mt Morris Michigan
those foam blocks, plastic or whatever there made of are about 600+. if i buy one, i sell it after im done with it.
Re: plastic engine blocks [Re: A727Tflite] #3123311
02/21/23 11:21 AM
02/21/23 11:21 AM
an8sec70cuda Offline
That's what I did. Used a 440 block w/ hemi heads bolted to it...set it in the car on the factory wedge motor mounts so I could fab the mounts for the motorplate and make sure the headers fit.
Unless you're using some sort of hemi conversion motor mount, you don't need a hemi block.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: plastic engine blocks [Re: mopar dave] #3123312
02/21/23 11:23 AM
02/21/23 11:23 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Make up a block out of cardboard, should get u close enough.
