Re: plastic engine blocks
[Re: Hot 340]
#3122714
02/19/23 01:05 AM
02/19/23 01:05 AM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I just use an old KB aluminum Hemi block I have with no sleeves. Weighs almost nothing. I lift in and out of the engine bays all the time by hand.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3122717
02/19/23 01:26 AM
02/19/23 01:26 AM
Posts: 11,683 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In my experience, the plastic replicas with threaded inserts are too flimsy to be used as a fixture for building parts and mounts.
[Re: mopar dave]
#3122834
02/19/23 02:32 PM
02/19/23 02:32 PM
Posts: 3,092 Michigan
A727Tflite
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance. Why can’t you just lay the Hemi heads on a 440.
[Re: Ray S]
#3122917
02/19/23 08:23 PM
02/19/23 08:23 PM
Posts: 2,080 CA
crackedback
CA
Wow, I never knew http://mockupmotors.comFor these prices I'd carve one out of pine https://www.speedwaymotors.com/shop/mock-up-engine-blocks~14-18-542-18045 If she comes with it, I'M IN!
[Re: mopar dave]
#3122995
02/20/23 07:50 AM
02/20/23 07:50 AM
Posts: 3,024 NY
B1duster
NY
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance. I have one I’d let you borrow but I’m in NY. Hopefully someone close by chimes in. I also remember reading the sizing was off, a little narrow
[Re: moparx]
#3123114
02/20/23 04:38 PM
02/20/23 04:38 PM
Posts: 4,696 On the parachute mount
n20mstr
??? FOR THOSE PRICES>???? Sorry but im a cheap M fer.....i would ask around for a blown up engine before i paid 400+ for a mock up block
....BAD A$$ STREET CAR.....
[Re: A727Tflite]
#3123311
02/21/23 11:21 AM
02/21/23 11:21 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance. Why can’t you just lay the Hemi heads on a 440. That's what I did. Used a 440 block w/ hemi heads bolted to it...set it in the car on the factory wedge motor mounts so I could fab the mounts for the motorplate and make sure the headers fit. Unless you're using some sort of hemi conversion motor mount, you don't need a hemi block.
