NV4500 fifth gear nut #3122861
02/19/23 04:52 PM
02/19/23 04:52 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I lost fifth gear in my '98 Cummins. I bought the nut kit that has the two small setscrews and the brass pucks. No instructions. I guess the brass pucks go in the holes first but is there a torque on the setscrews? I also bought the retainer that has the four "fingers" that fit into the nut. Anyone have any experience with this piece?
Re: NV4500 fifth gear nut [Re: 6PakBee] #3122865
02/19/23 05:10 PM
02/19/23 05:10 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
No experience rebuilding but I went through 7 of those damn transmissions because of that nut! The last 3 had the fix to keep it from backing out, didn't freakin' work! mad
JB Rhinehart, Realist
A-Body's RULE!
Re: NV4500 fifth gear nut [Re: 6PakBee] #3122871
02/19/23 05:32 PM
02/19/23 05:32 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Is there anything on youtube? shruggy
Re: NV4500 fifth gear nut [Re: Rhinodart] #3122904
02/19/23 07:51 PM
02/19/23 07:51 PM
Guitar Jones Offline
I don't have any experience with those kits, but I do know it is really only a problem with the Cummins trucks, gas trucks don't do it. Must be something about the harmonics in the Cummins that knocks the nut loose.
Re: NV4500 fifth gear nut [Re: 6PakBee] #3122906
02/19/23 07:55 PM
02/19/23 07:55 PM
Torque King has instructual videos on you tube.
Re: NV4500 fifth gear nut [Re: 6PakBee] #3122944
02/19/23 09:57 PM
02/19/23 09:57 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
You bought a kit and they did not show instructions? Send it back. Just google the 5th gear nut. That fix is garbage.
Re: NV4500 fifth gear nut [Re: NITROUSN] #3122946
02/19/23 10:08 PM
02/19/23 10:08 PM
N
N
You need the special nut wrench to properly torque the nut. https://torqueking.com/nv4500-5th-gear-failures-and-solutions/
Re: NV4500 fifth gear nut [Re: NITROUSN] #3122977
02/20/23 12:08 AM
02/20/23 12:08 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I bought both special tools, the spanner for the nut and the splined holder for the shaft. The reason I asked the question on this forum is that typically people who respond are more responsible when repairing equipment. What I saw on line were people using the wrong sealant on the transmission extension housing and tightening the gear nut with a hammer and chisel. So people who went on and on about their 3rd, 4th, 5th failure....I don't know if they knew what they were doing or they were just following the YouTube "mechanics".
Re: NV4500 fifth gear nut [Re: 6PakBee] #3123024
02/20/23 10:32 AM
02/20/23 10:32 AM
N
N
Clean it well, red loctite, new nut and this lock ring.Lock
Re: NV4500 fifth gear nut [Re: NITROUSN] #3123040
02/20/23 11:23 AM
02/20/23 11:23 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I have that lock ring as well. As to the Loctite, I'm looking at 648 for the splines on the gear and 263 for the nut.
Re: NV4500 fifth gear nut [Re: 6PakBee] #3123199
02/20/23 10:44 PM
02/20/23 10:44 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Give Dan Brewer a call and he can tell you how to fix it!
Re: NV4500 fifth gear nut [Re: max_maniac] #3124717
02/26/23 10:07 AM
02/26/23 10:07 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Well, put 5th gear together last night. After more than one email with the Loctite tech line, settled on 648 for the gear and 277 for the nut. Initially torqued it to 250 lb-ft (that's all the torque wrench I have) as the factory specification is 250-300 ft-lbs. I then used a breaker bar and a cheater and torqued the living bejesus out of the nut. So I have a new gear, new nut with the two set screws, and the pronged retainer. We'll see how this works out.
luck
Re: NV4500 fifth gear nut [Re: 6PakBee] #3124738
02/26/23 11:19 AM
02/26/23 11:19 AM
moparx Offline
moparx  Offline
and as a very last resort, break out the welder for two big tacks. whistling boogie
hackery at it's finest ! biggrin
beer
Re: NV4500 fifth gear nut [Re: moparx] #3125439
02/28/23 09:20 PM
02/28/23 09:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
beer
I’ve seen that broken…..
