NV4500 fifth gear nut
#3122861
02/19/23 04:52 PM
02/19/23 04:52 PM
Posts: 10,723 North Dakota
6PakBee
North Dakota
I lost fifth gear in my '98 Cummins. I bought the nut kit that has the two small setscrews and the brass pucks. No instructions. I guess the brass pucks go in the holes first but is there a torque on the setscrews? I also bought the retainer that has the four "fingers" that fit into the nut. Anyone have any experience with this piece?
Re: NV4500 fifth gear nut
[Re: Rhinodart]
#3122904
02/19/23 07:51 PM
02/19/23 07:51 PM
Guitar Jones
I don't have any experience with those kits, but I do know it is really only a problem with the Cummins trucks, gas trucks don't do it. Must be something about the harmonics in the Cummins that knocks the nut loose.
[Re: 6PakBee]
#3122906
02/19/23 07:55 PM
02/19/23 07:55 PM
Guitar Jones
I lost fifth gear in my '98 Cummins. I bought the nut kit that has the two small setscrews and the brass pucks. No instructions. I guess the brass pucks go in the holes first but is there a torque on the setscrews? I also bought the retainer that has the four "fingers" that fit into the nut. Anyone have any experience with this piece? Torque King has instructual videos on you tube.
[Re: 6PakBee]
#3122944
02/19/23 09:57 PM
02/19/23 09:57 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I lost fifth gear in my '98 Cummins. I bought the nut kit that has the two small setscrews and the brass pucks. No instructions. I guess the brass pucks go in the holes first but is there a torque on the setscrews? I also bought the retainer that has the four "fingers" that fit into the nut. Anyone have any experience with this piece? You bought a kit and they did not show instructions? Send it back. Just google the 5th gear nut. That fix is garbage.
[Re: NITROUSN]
#3122977
02/20/23 12:08 AM
02/20/23 12:08 AM
6PakBee
North Dakota
I bought both special tools, the spanner for the nut and the splined holder for the shaft. The reason I asked the question on this forum is that typically people who respond are more responsible when repairing equipment. What I saw on line were people using the wrong sealant on the transmission extension housing and tightening the gear nut with a hammer and chisel. So people who went on and on about their 3rd, 4th, 5th failure....I don't know if they knew what they were doing or they were just following the YouTube "mechanics".
[Re: NITROUSN]
#3123040
02/20/23 11:23 AM
02/20/23 11:23 AM
6PakBee
North Dakota
Clean it well, red loctite, new nut and this lock ring. Lock I have that lock ring as well. As to the Loctite, I'm looking at 648 for the splines on the gear and 263 for the nut.
[Re: moparx]
#3125439
02/28/23 09:20 PM
02/28/23 09:20 PM
Posts: 13,194 aZLiViN
J_BODY
aZLiViN
