Alternator Belt #3119974
02/08/23 02:31 PM
02/08/23 02:31 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 Challenger 440 mag stock alternator. Which manufacture sell a belt that look like a orginal ?
Re: Alternator Belt [Re: ct440rod] #3120062
02/08/23 07:44 PM
02/08/23 07:44 PM
MoreParts Offline
MoreParts  Offline
Check Mancini Racing.
Re: Alternator Belt [Re: ct440rod] #3120131
02/09/23 01:31 AM
02/09/23 01:31 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Tractor Supply, they still have solid (non-cogged) belts.
Re: Alternator Belt [Re: HEMICUDA] #3120194
02/09/23 11:18 AM
02/09/23 11:18 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I dislike seeing a cogged belt on a earlier mopar. I have had good luck finding Mopar belts on ebay. Some of the later mopar V belts can be had fairly cheap. Those later versions usually start with a B000 number. The part number will tell you the size and width. Example https://www.ebay.com/itm/174079563706
Re: Alternator Belt [Re: mopars4ever] #3120217
02/09/23 12:30 PM
02/09/23 12:30 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
So if the belt I took off is 47.57 o.c. and .44 width what would that translate to Mopar number ?
thanks
Re: Alternator Belt [Re: ct440rod] #3120561
02/10/23 09:11 PM
02/10/23 09:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Look at the belt guide on the back of the belt. This one should be 48 1/2. https://www.ebay.com/itm/184185051799
Re: Alternator Belt [Re: mopars4ever] #3120564
02/10/23 09:16 PM
02/10/23 09:16 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Here is a 47.5 but it is a jeep belt not cogged in the pic but i would ask first to make sure. https://www.ebay.com/itm/124884805460
Re: Alternator Belt [Re: mopars4ever] #3121220
02/13/23 04:54 PM
02/13/23 04:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I bought some belts from Quanta and they look pretty legit.
Got them from Classic Industries.
Re: Alternator Belt [Re: topside] #3121227
02/13/23 05:12 PM
02/13/23 05:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t know for sure and maybe they have changed but if I remember correctly that the people who used those belts had problems with them stretching.
Re: Alternator Belt [Re: mopars4ever] #3121247
02/13/23 06:46 PM
02/13/23 06:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Interesting - I hadn't given it a thought. - but thanks for the heads-up.
So I googled around, and there are numerous posts on different forums - including a Vette forum - about the Quanta belts stretching, twisting, and/or "flying off".
Whether that's still an issue years later, I can't tell, as there were no posts more recent than 10 years ago.
I'll have to see if anything else pops up before I install the things, and the existing belts appear fine and operate quietly anyway.
My thought at the time was to put the most correct ones I could find on the car; but I won't run junk if that's the case.
Re: Alternator Belt [Re: topside] #3121616
02/14/23 09:52 PM
02/14/23 09:52 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Years ago I had read the same negative statements regarding quanta belts, well I bought them and have had ZERO issues. Have them on two vehicles one of which they have been on for at least seven years and I have never had to retighten the. I’m currently doing a third car and it will also have them. Oh I am not an employee, relative ,etc.etc of anyone from that company either. Finally they do look the part, do not know of a belt that looks more original than an original.
Re: Alternator Belt [Re: 340cpe] #3122162
02/16/23 08:38 PM
02/16/23 08:38 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
and how much do you drive these cars???
5549 post on old board
Re: Alternator Belt [Re: 05dakota] #3122332
02/17/23 01:40 PM
02/17/23 01:40 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
So i think i have right belt size now 1/2 by 47.5 but now the belt is to big for the pulley on alternator. Do they make different size pulleys for alternators ?
Re: Alternator Belt [Re: ct440rod] #3122336
02/17/23 02:01 PM
02/17/23 02:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
1/2 is too wide. Pulleys should be all the same for those years. Just single or dual groove
Re: Alternator Belt [Re: 05dakota] #3122455
02/17/23 10:52 PM
02/17/23 10:52 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
The car I’ve had them on for seven years several hundred miles a year average over that period.
Re: Alternator Belt [Re: 340cpe] #3122467
02/18/23 12:26 AM
02/18/23 12:26 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I put resto belts on last year and they were pure garbage. Stretched within 100 miles. Trash. Think they were quanta. I found some Continental belts at Summit that at least have flat and not cogged.
I want my fair share
Re: Alternator Belt [Re: topside] #3122568
02/18/23 03:58 PM
02/18/23 03:58 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Here in Canada I replaced mine with the same Dayco I had been running for years for my 360.
Re: Alternator Belt [Re: CDN72SE] #3122600
02/18/23 05:37 PM
02/18/23 05:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
he is looking for original looking belts, I assume he means not cogged.
