Trend Pushrod Length Checker Needed #3120085
02/08/23 09:16 PM
02/08/23 09:16 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Does anyone have a Trend Performance pushrod length checker I could buy? They have been on back order for a few months and I'd like to get this car back together.
Their part # TC8898C which is 8.8"-9.8" and a 5/16 cup.
Thanks !
Re: Trend Pushrod Length Checker Needed [Re: jcastle1] #3120168
02/09/23 09:07 AM
02/09/23 09:07 AM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
I used the one from 440 Source
then you need a 10" dial Caliper that you can use to measure the length. I ordered that off amazon. Worked out OK for me, took all my measurements, then called trend and they had my pushrods made and delivered within the week.
https://store.440source.com/Adjustable-Checking-Pushrod-RB/productinfo/200-1098/
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: Trend Pushrod Length Checker Needed [Re: jcastle1] #3120192
02/09/23 11:03 AM
02/09/23 11:03 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Jesel sells one, works pretty well.
https://www.summitracing.com/parts/jes-tol-29425
Rich H.
Esse Quam Videri
Re: Trend Pushrod Length Checker Needed [Re: ZIPPY] #3120374
02/10/23 12:05 AM
02/10/23 12:05 AM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
I have both Jesel kits, a comp and a Smith Brothers.
The Smith Bros kit is cool beacuse the tool is 5/16. The rest I have used (jegs, summit etc) are 3/8" which is good for a race engine but not needed for a mild HFT in a streeter.
As an example, the Stealth heads require clearancing for 3/8 push rods. If you were to run a 5/16 PR you would have to clearance the head just for the tool.
I can post pics of the seta I have if that helps
Re: Trend Pushrod Length Checker Needed [Re: Jeremiah] #3120448
02/10/23 01:25 PM
02/10/23 01:25 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Yea, I'll be using the 5/16 pushrods due to the sidewinder heads will not open up far enough to accept 3/8
Re: Trend Pushrod Length Checker Needed [Re: jcastle1] #3120455
02/10/23 01:53 PM
02/10/23 01:53 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I'm heading home. We can use mine on Sunday. If mine won't work will be a good excuse to finally get the lathe wired up again.
And you ain't doing it without me since I have your heads! LOL!
Re: Trend Pushrod Length Checker Needed [Re: markz528] #3120560
02/10/23 09:05 PM
02/10/23 09:05 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
thanks!
Re: Trend Pushrod Length Checker Needed [Re: jcastle1] #3120607
02/11/23 02:31 AM
02/11/23 02:31 AM
Rogue River, OR
Rogue River, OR
Smith bros in red
Re: Trend Pushrod Length Checker Needed [Re: Jeremiah] #3122209
02/16/23 11:52 PM
02/16/23 11:52 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Well this should work.
