I kind of like this Indy cross ram
#31198
09/25/06 01:18 AM
09/25/06 01:18 AM
Posts: 31,050 Oregon
AndyF
This thing looks promising. I need to get it on the dyno to see how well it works but so far I rather like it. It did take me a couple of hours of grinding to get it to clear the MSD distributor and to get the port matching correct. I still need to put it in the Bridgeport and counterbore for the intake bolts since they are cast at an angle. I'm thinking it should run pretty good with a couple of Eddy 800 carbs on top but I'm wondering if it might just be a cool street setup with a six pack? I know the stock six pack setup runs out of power on big motors but this sucker might just work.
Re: I kind of like this Indy cross ram
[Re: AndyF]
#31200
09/25/06 02:09 AM
09/25/06 02:09 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
With the huge plenum volume, it mey not be a very good street intake even with the six pack.
Plynouth VIP '67 TT IC EFI
[Re: PHJ426]
#31204
09/25/06 07:00 AM
09/25/06 07:00 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my vote goes to a 6 pack lid with 3 4412 holleys and spacing for the center hung float bowls
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#31206
09/25/06 10:04 AM
09/25/06 10:04 AM
Posts: 1,843 Maryland
OriginalRT
Maryland
or how about 4 2bbls, one over each set of runners in a 1 to 1 ratio. bad gas milage though
That'd be slick! Kinda like a split dominator set up.
[Re: AndyF]
#31207
09/25/06 11:58 AM
09/25/06 11:58 AM
Posts: 16,928 NC
440Jim
NC
The bolt holes are not straight with the head threaded holes??? That is terrible.
But I think it will make good power.
[Re: OriginalRT]
#31213
09/25/06 09:46 PM
09/25/06 09:46 PM
AndyF
I had to grind away a bunch of the mounting bolt boss since it was running into the distributor. The odd thing is that the boss isn't even needed that low since the screw is only about 1/2 inch long. So it was just a hunk of aluminum hanging out there. Then I had to grind a shallow cup into the front of the manifold to clear the side of the distributor. It was probably 0.060 thick section about the size of a silver dollar.
[Re: AndyF]
#31214
09/25/06 11:39 PM
09/25/06 11:39 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Andy, as far as which set up will make the most power I'm betting on the stocker type cross ram with the 1600 CFM. Make sure and watch your jetting via the spark plugs, AFR sensors and EGTs if you can. BTW I will be glad to do some track testing on those combo in my car with my MW port SR 527 motor, Let me know if your interested in doing some at the track testing. Oops, sorry. I put this on the wrong post. Anyway the offer still stands.
