Editing a post in the unmoderated forum? #3119606
02/07/23 01:54 PM
02/07/23 01:54 PM
IMGTX Offline OP
IMGTX  Offline OP
I saw some spelling errors in my last post and found the edit button missing.
I can reply to it but I can not edit my own posts.
I can here but not there.
I this normal or did I miss something?
Re: Editing a post in the unmoderated forum? [Re: IMGTX] #3119608
02/07/23 02:01 PM
02/07/23 02:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally Posted by IMGTX
I this normal
I had to laugh, thank you. :-)
Normal is overrated anyway.....
Re: Editing a post in the unmoderated forum? [Re: IMGTX] #3119610
02/07/23 02:05 PM
02/07/23 02:05 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Just be happy that you can spell correctly. Most folks on this board are 'challenged' in that area. twocents
Re: Editing a post in the unmoderated forum? [Re: Hugh Jorgan] #3119630
02/07/23 02:47 PM
02/07/23 02:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I find it's most people in LIFE!
'63 Dodge 330
11.19 @ 121 mph
Re: Editing a post in the unmoderated forum? [Re: IMGTX] #3119651
02/07/23 03:46 PM
02/07/23 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Evidently it is on that forum, not so here. Why? shruggy
Re: Editing a post in the unmoderated forum? [Re: 3hundred] #3119662
02/07/23 04:08 PM
02/07/23 04:08 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
There is a time limit on editing posts in that forum, you've got to be quack (on purpose, for fun) about it.
iagree
My Monster are real!
Living within your means makes life pretty easy.
Re: Editing a post in the unmoderated forum? [Re: 67vertman] #3119668
02/07/23 04:30 PM
02/07/23 04:30 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Once something is posted on the unmoderated board, you have maybe 2 minutes to correct it before its written in stone, and that would include the time it takes to make a correction. If you wrote something there, you better read it as soon as its posted so you might be able to correct it. If there are a few things that need to be corrected, you might be better off deleting it and writing it again, or attempt a few runs at the small open window of the correction time. Edit, make a couple quick corrections, post it, then edit it again. I know you can do that at least 2 times if your quick enough. Each posting resets the time frame. I have have had it time out while I was making corrections, in which case, its there for eternity as originally posted.
Re: Editing a post in the unmoderated forum? [Re: poorboy] #3119681
02/07/23 05:06 PM
02/07/23 05:06 PM
IMGTX Offline OP
IMGTX  Offline OP
Ahh That makes sense.
I am old school and want to spell correctly so if I see an error I like to change them.
I guess I will have to be more careful on the few posts I make there. up
Re: Editing a post in the unmoderated forum? [Re: IMGTX] #3119689
02/07/23 05:32 PM
02/07/23 05:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You have a few minutes to fix it. Then you own it.
It's like a text message. You better be sure of what it says and who will see it before you hit send.
Re: Editing a post in the unmoderated forum? [Re: CMcAllister] #3119699
02/07/23 06:03 PM
02/07/23 06:03 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
But then there can't be any dirty deletes and people have to own their statements. That just doesn't seem fair...
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Editing a post in the unmoderated forum? [Re: IMGTX] #3119711
02/07/23 06:38 PM
02/07/23 06:38 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I want to personally commend you for respecting yourself and the language enough to get it right.
