Re: Editing a post in the unmoderated forum?
[Re: IMGTX]
#3119608
02/07/23 02:01 PM
02/07/23 02:01 PM
Posts: 29,656 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I had to laugh, thank you. :-) Normal is overrated anyway.....
[Re: Hugh Jorgan]
#3119630
02/07/23 02:47 PM
02/07/23 02:47 PM
Posts: 4,700 Wichita
GY3
Wichita
Just be happy that you can spell correctly. Most folks on this board are 'challenged' in that area. I find it's most people in LIFE!
[Re: IMGTX]
#3119651
02/07/23 03:46 PM
02/07/23 03:46 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I saw some spelling errors in my last post and found the edit button missing.
I can reply to it but I can not edit my own posts.
I can here but not there.
I this normal or did I miss something? Evidently it is on that forum, not so here. Why?
[Re: 3hundred]
#3119662
02/07/23 04:08 PM
02/07/23 04:08 PM
Posts: 4,810 Star Idaho
67vertman
Star Idaho
I this normal or did I miss something? There is a time limit on editing posts in that forum, you've got to be quack (on purpose, for fun) about it.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3119668
02/07/23 04:30 PM
02/07/23 04:30 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
Once something is posted on the unmoderated board, you have maybe 2 minutes to correct it before its written in stone, and that would include the time it takes to make a correction. If you wrote something there, you better read it as soon as its posted so you might be able to correct it. If there are a few things that need to be corrected, you might be better off deleting it and writing it again, or attempt a few runs at the small open window of the correction time. Edit, make a couple quick corrections, post it, then edit it again. I know you can do that at least 2 times if your quick enough. Each posting resets the time frame. I have have had it time out while I was making corrections, in which case, its there for eternity as originally posted.
[Re: IMGTX]
#3119689
02/07/23 05:32 PM
02/07/23 05:32 PM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You have a few minutes to fix it. Then you own it.
It's like a text message. You better be sure of what it says and who will see it before you hit send.
[Re: CMcAllister]
#3119699
02/07/23 06:03 PM
02/07/23 06:03 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
It's like a text message. You better be sure of what it says and who will see it before you hit send. But then there can't be any dirty deletes and people have to own their statements. That just doesn't seem fair...
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: IMGTX]
#3119711
02/07/23 06:38 PM
02/07/23 06:38 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ahh That makes sense. I am old school and want to spell correctly so if I see an error I like to change them. I guess I will have to be more careful on the few posts I make there. I want to personally commend you for respecting yourself and the language enough to get it right.
