93 Ram diesel heater control issue #3116153
01/24/23 08:02 PM
01/24/23 08:02 PM
birdtracker Offline OP
my truck won't produce air from the floor or defroster, It puts it out on vent but as soon as you push floor or defrost its like you turned the blower off. Any ideas? Birdtracker
Re: 93 Ram diesel heater control issue [Re: birdtracker] #3116160
01/24/23 08:44 PM
01/24/23 08:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
There are known problems with the air passage doors inside the HVAC unit that fail, all the air doors are controlled by vacuum, so the place to start is at the vacuum switch, actuators and the vacuum lines and be sure everything with them is working as it should.
A diesel may have a vacuum pump, probably should start there. low vacuum will mess up the door function fast.
Re: 93 Ram diesel heater control issue [Re: poorboy] #3116477
01/25/23 04:24 PM
01/25/23 04:24 PM
moparx Offline
moparx  Offline
the first thing i would do, is use a hand pump vacuum source to check the blend door[s] function. if they work as they should, i would take a good look at the hoses, then the dash control.
all checks would be done using the hand pump vacuum source.
beer
Re: 93 Ram diesel heater control issue [Re: moparx] #3116640
01/26/23 07:02 AM
01/26/23 07:02 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Iirc on most systems regardless of mfr, defrost is the default no vacuum mode.
You're problem sounds like the control head is failing, especially if losing blower motor operation.
Angry white pureblood male
Re: 93 Ram diesel heater control issue [Re: ruderunner] #3116876
01/26/23 10:08 PM
01/26/23 10:08 PM
Guitar Jones Offline
I agree, the push button switch is where I would go first. I bet there is a crispy connector on the back and some overheated wires.
Have you checked anything before asking questions?
Re: 93 Ram diesel heater control issue [Re: Guitar Jones] #3117345
01/28/23 08:26 PM
01/28/23 08:26 PM
I have had the glove box opened up and can get to the vaccum hoses. It appears to switch from defrost to vent and floor. Birdtracker
Re: 93 Ram diesel heater control issue [Re: birdtracker] #3117451
01/29/23 08:46 AM
01/29/23 08:46 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Does the blower motor actually stop running? Or is it simply the airflow getting cut off?
When checking for vacuum behind the glove box, can you see if the can is moving the air door?
Re: 93 Ram diesel heater control issue [Re: ruderunner] #3117583
01/29/23 08:26 PM
01/29/23 08:26 PM
the blower motor actually stops as I go out under the hood and its not running. The odd thing is when I move the mode it changes but I don't see anything moving. Unfortunately the weather has been pure crap and now the temps are going back down into the teens. My son loaned me a Jeep to drive so its not a crisis. Guess I will have to take the cluster bezel off and look behind the switches. Birdtracker
Re: 93 Ram diesel heater control issue [Re: birdtracker] #3117725
01/30/23 01:49 PM
01/30/23 01:49 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I see Ohio plates. What region?
Re: 93 Ram diesel heater control issue [Re: ruderunner] #3117822
01/30/23 10:22 PM
01/30/23 10:22 PM
just north of Dayton. Birdtracker
Re: 93 Ram diesel heater control issue [Re: birdtracker] #3117966
01/31/23 06:20 PM
01/31/23 06:20 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Too far to stop by and check it out.
