Re: 93 Ram diesel heater control issue
[Re: moparx]
#3116640
01/26/23 07:02 AM
01/26/23 07:02 AM
Posts: 5,850 ohio
ruderunner
ohio
Iirc on most systems regardless of mfr, defrost is the default no vacuum mode.
You're problem sounds like the control head is failing, especially if losing blower motor operation.
Angry white pureblood male
[Re: ruderunner]
#3116876
01/26/23 10:08 PM
01/26/23 10:08 PM
Guitar Jones
You're problem sounds like the control head is failing, especially if losing blower motor operation. I agree, the push button switch is where I would go first. I bet there is a crispy connector on the back and some overheated wires. Have you checked anything before asking questions?
[Re: birdtracker]
#3117451
01/29/23 08:46 AM
01/29/23 08:46 AM
Posts: 5,850 ohio
ruderunner
ohio
Does the blower motor actually stop running? Or is it simply the airflow getting cut off?
When checking for vacuum behind the glove box, can you see if the can is moving the air door?
[Re: ruderunner]
#3117583
01/29/23 08:26 PM
01/29/23 08:26 PM
birdtracker
the blower motor actually stops as I go out under the hood and its not running. The odd thing is when I move the mode it changes but I don't see anything moving. Unfortunately the weather has been pure crap and now the temps are going back down into the teens. My son loaned me a Jeep to drive so its not a crisis. Guess I will have to take the cluster bezel off and look behind the switches. Birdtracker
[Re: birdtracker]
#3117725
01/30/23 01:49 PM
01/30/23 01:49 PM
Posts: 5,850 ohio
ruderunner
ohio
I see Ohio plates. What region?
[Re: birdtracker]
#3117966
01/31/23 06:20 PM
01/31/23 06:20 PM
Posts: 5,850 ohio
ruderunner
ohio
Too far to stop by and check it out.
