Re: J11Y
[Re: Kudakidd]
#3116246
01/25/23 03:20 AM
01/25/23 03:20 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Back in the day (my day at least), these were the Champion spark plugs to run in a big block. Is it still the same today, and where's the best place to buy them? Probably not going to find them now due to smog rules, resistor plugs only now I thnk that champion quit making the J11Y and RJ11Y a long time ago, RJ10Y, RJ10YC or RJ12Y, RJ12YC available now
Re: J11Y
[Re: quickd100]
#3116404
01/25/23 01:35 PM
01/25/23 01:35 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
You might be ok with NOS ones, but if I buy something that has champions those get chucked right away for NGKs. Have solved a lot of running issues getting those out of the engines.
I want my fair share
Re: J11Y
[Re: Kudakidd]
#3116412
01/25/23 02:00 PM
01/25/23 02:00 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Back in the day (my day at least), these were the Champion spark plugs to run in a big block. Is it still the same today, and where's the best place to buy them? New old stock is your only source they stopped making that plug decades ago.
Re: J11Y
[Re: Kudakidd]
#3116535
01/25/23 08:08 PM
01/25/23 08:08 PM
Posts: 3,916 usa
lewtot184
usa
So what is the big block choice of plugs nowadays? probably the autolite 85 or the ngk thing. rj12y's aren't very good. not sure AC numbers would work but just make sure you use a projected tip. i really don't buy anything buy brand name exclusively anymore. and sure don't follow the internet/magazine herd. i just look for what fits my needs and works and forget about names on the part.
Re: J11Y
[Re: lewtot184]
#3116538
01/25/23 08:20 PM
01/25/23 08:20 PM
Posts: 16,545 On the run…
BloFish
On the run…
I run NGK BKR5ES-11 with aluminum heads for what that’s worth.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: J11Y
[Re: Kudakidd]
#3116559
01/25/23 09:24 PM
01/25/23 09:24 PM
Cab_Burge
Re: J11Y
[Re: lewtot184]
#3116651
01/26/23 08:44 AM
01/26/23 08:44 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
This has been posted here a few times. I use NGK -6's for street driving and have moved to -8's when I'm spraying.
Re: J11Y
[Re: lewtot184]
#3116686
01/26/23 11:24 AM
01/26/23 11:24 AM
JohnRR
So what is the big block choice of plugs nowadays? probably the autolite 85 or the ngk thing. rj12y's aren't very good. not sure AC numbers would work but just make sure you use a projected tip. i really don't buy anything buy brand name exclusively anymore. and sure don't follow the internet/magazine herd. i just look for what fits my needs and works and forget about names on the part. Becareful with the Autolite 85, new isn't the same as old ... that was my go to plug for a while ... when they moved production to Mexico years ago the quality went to poo poo , electrodes offset in the porcelain. Mark I'd look at the NGK listed in the photo Nick posed , XR4 , or go on fleabay and find a set of the Mopar branded NOS plugs 34P , P34P , they are the J-11Y equivalent.
Re: J11Y
[Re: John Brown]
#3117168
01/27/23 09:46 PM
01/27/23 09:46 PM
Cab_Burge
The N series Champion plugs are 3/4 reach, the J series are 5/8 reach, not interchangeable J series threads are 9.5mm which is closer to 3/8 inch. Ich nix verstain metric
