J11Y #3116156
01/24/23 08:36 PM
01/24/23 08:36 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Back in the day (my day at least), these were the Champion spark plugs to run in a big block. Is it still the same today, and where's the best place to buy them?
Re: J11Y [Re: Kudakidd] #3116209
01/24/23 11:02 PM
01/24/23 11:02 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Get new old- old stock on ebay. In this style box. Champions kinda went bad somewhere in the 80s iirc.
Re: J11Y [Re: Kudakidd] #3116246
01/25/23 03:20 AM
01/25/23 03:20 AM
Probably not going to find them now due to smog rules, resistor plugs only now scope
I thnk that champion quit making the J11Y and RJ11Y a long time ago, RJ10Y, RJ10YC or RJ12Y, RJ12YC available now scope
Re: J11Y [Re: Cab_Burge] #3116301
01/25/23 06:44 AM
01/25/23 06:44 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I would suggest the appropriate NGK. I've had to many problems with Champions.
Re: J11Y [Re: quickd100] #3116404
01/25/23 01:35 PM
01/25/23 01:35 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You might be ok with NOS ones, but if I buy something that has champions those get chucked right away for NGKs. Have solved a lot of running issues getting those out of the engines.
I want my fair share
Re: J11Y [Re: Kudakidd] #3116412
01/25/23 02:00 PM
01/25/23 02:00 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
New old stock is your only source they stopped making that plug decades ago.
Re: J11Y [Re: JohnRR] #3116439
01/25/23 03:26 PM
01/25/23 03:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i like j11y's. stocked up on them years ago. j11y and j13y were designed specifically for the mopar combustion chamber. j11y tip gets a little further in the chamber. i've used ngk's and autolites too but their no better than the j11y. only down side to a j11y i can think of is they're fairly cold.
Re: J11Y [Re: lewtot184] #3116532
01/25/23 07:56 PM
01/25/23 07:56 PM
Kudakidd Offline OP
Kudakidd  Offline OP
So what is the big block choice of plugs nowadays?
Re: J11Y [Re: Kudakidd] #3116535
01/25/23 08:08 PM
01/25/23 08:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
probably the autolite 85 or the ngk thing. rj12y's aren't very good. not sure AC numbers would work but just make sure you use a projected tip. i really don't buy anything buy brand name exclusively anymore. and sure don't follow the internet/magazine herd. i just look for what fits my needs and works and forget about names on the part.
Re: J11Y [Re: lewtot184] #3116538
01/25/23 08:20 PM
01/25/23 08:20 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I run NGK BKR5ES-11 with aluminum heads for what that’s worth.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: J11Y [Re: Kudakidd] #3116559
01/25/23 09:24 PM
01/25/23 09:24 PM
Autolite 3911 race plug or the resistor street plug # 3923,3924 or maybe the colder 3923 or 3922 with aluminum heads nowscope up twocents
Re: J11Y [Re: Cab_Burge] #3116649
01/26/23 08:06 AM
01/26/23 08:06 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if the OP is asking about j11y's then i'd have assume he's referring to 14mm/3/8" reach/projected tip plug for iron heads.
Re: J11Y [Re: lewtot184] #3116651
01/26/23 08:44 AM
01/26/23 08:44 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
This has been posted here a few times. I use NGK -6's for street driving and have moved to -8's when I'm spraying.
Re: J11Y [Re: lewtot184] #3116686
01/26/23 11:24 AM
01/26/23 11:24 AM
JohnRR Offline
JohnRR  Offline
Becareful with the Autolite 85, new isn't the same as old ... that was my go to plug for a while ... when they moved production to Mexico years ago the quality went to poo poo , electrodes offset in the porcelain.
Mark I'd look at the NGK listed in the photo Nick posed , XR4 , or go on fleabay and find a set of the Mopar branded NOS plugs 34P , P34P , they are the J-11Y equivalent.
Re: J11Y [Re: JohnRR] #3116688
01/26/23 11:26 AM
01/26/23 11:26 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I ran autolite 85s for years…then Mexico happened.
Re: J11Y [Re: SomeCarGuy] #3116769
01/26/23 03:45 PM
01/26/23 03:45 PM
moparx Offline
moparx  Offline
i have a set of N-12yc's i don't think i'm going to use.
pm if interested. they are on the shelf for now.
beer
Re: J11Y [Re: moparx] #3116920
01/27/23 02:05 AM
01/27/23 02:05 AM
The N series Champion plugs are 3/4 reach, the J series are 5/8 reach, not interchangeable tsk scope
Re: J11Y [Re: Cab_Burge] #3117070
01/27/23 02:08 PM
01/27/23 02:08 PM
moparx Offline
moparx  Offline
right you are Cab. my bad. spank
sorry.
beer
Re: J11Y [Re: Cab_Burge] #3117109
01/27/23 04:35 PM
01/27/23 04:35 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
J series threads are 9.5mm which is closer to 3/8 inch.
Re: J11Y [Re: John Brown] #3117168
01/27/23 09:46 PM
01/27/23 09:46 PM
Ich nix verstain metric down
