Are you ready for an E-Turbo?
#3115956
01/24/23 10:40 AM
01/24/23 10:40 AM
Posts: 12,127 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
" In May 2021 Hot Rod they had an article about E-Turbos that I found interesting. Basically, it is a modified turbocharger with an electric motor that also can use the exhaust energy to charge a battery. If I understand the technology correctly, the electric motor will spool the turbo faster but during normal driving use the waste exhaust energy to recharge a battery.
For max acceleration the car can not only use the ICE power but also the electric motors. During normal driving using the motor, it can charge the battery for the electric motors. Garrett and Borg Warner are both working on these for both 12v and 48v systems.
Lots of new technology surrounding this including high speed motors and controls. It appears this will be first used in hybrid cars but F1 Racing has played with it and I can see the technology spilling over into drag cars." www.garrettmotion.com/electric-hybrid/garrett-e-turboeBooster® Electrically Driven Compressor
BorgWarner’s eBooster® electrically driven compressor supplements conventional turbocharging systems. Placed either upstream or downstream of the regular turbocharger, the eBooster solution improves boost pressure and transient engine response at low engine speeds. In doing so, the technology virtually eliminates turbo lag.
The eBooster® permits the development of small and efficient high-performance turbocharged engines whose dynamic response matches that of large non-supercharged engines of the same output class. The superiority of the eBooster® was impressively demonstrated in close cooperation with various customers for gasoline engines as well as for diesel engines. www.borgwarner.com/technologies/electric-boosting-technologies
Master, again and still
Re: Are you ready for an E-Turbo?
[Re: DaveRS23]
#3116353
01/25/23 11:07 AM
01/25/23 11:07 AM
Posts: 4,206 New York
polyspheric
New York
Eventually, the politics becomes visible. Washington (and many blue States) want NO fuel-burning vehicles produced, as soon as possible (except for limousines). After that, none can be sold. After that, punitive taxation. After that, seized.
Did you think Gavin Newsom is your friend?
Boffin Emeritus
[Re: polyspheric]
#3116530
01/25/23 07:43 PM
01/25/23 07:43 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This is not the place for political posts. This post was not an endorsement of EVs or anything like that. I just thought the guy proved that he knows his $hit. Isn't it an interesting application in and of itself? I thought so.
[Re: DaveRS23]
#3116620
01/26/23 12:39 AM
01/26/23 12:39 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Hot Rod Magazine (I think) did a tech story on F1 Motor Generator Units. If I remember correctly, the cold side (induction) was located at the front of the engine and there was a shaft that went through the valley area and connected to the hot side at the rear of the engine. Also mounted to the shaft was a motor/generator. When you didn't need more boost, the motor/generator went into generator mode and charged the battery. The Generator could also act like a JakeBrake and slow the car down. And the turbo was oversize ... to eliminate turbo lag, the ECU sent energy to the motor/generator to act like a motor and spin up the turbo. I read that article several times just to try to get a grasp on all the technology. I couldn't find a link to the article but I did find: https://f1.fandom.com/wiki/Motor_Generator_Unit_-_Heat Super cool stuff ... now how can I retrofit that to my Gen II HEMI and add all that programming to my MegaSquirt ECU?
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
