Hemi ray barton valve covers in e body
#3115781
01/23/23 07:09 PM
01/23/23 07:09 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Does anyone have a hemi e body with the ray barton valve covers? If so, do they hit the inner fenders? Originally I had a small block k member with the Schumacher conversion mounts and now I have a hemi k member conversion from Al Debevec and the passenger side valve cover hits the inner fender and blower motor with both setups. Any trick to getting it to fit without denting the inner fender?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Hemi ray barton valve covers in e body
[Re: NITROUSN]
#3115788
01/23/23 07:57 PM
01/23/23 07:57 PM
73cuda340
clarks summit pa
He told me that he hasn't had any issues and that they fit. However, I have had nothing but issues with the motor since I bought it and they have been zero help , so I'm not sure if they're just saying they fit fine.
[Re: 73cuda340]
#3115800
01/23/23 08:55 PM
01/23/23 08:55 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have a pair of Barton covers on my mock up display Hemi in the Racement (racing themed basement), but never used them to mock up in my B Bodies or E Body. I do have the tapered passenger Indy covers on my Hemi in my E Body. They do give you any extra clearance that you may need. If you look closely you can see the tapered section in the center.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#3115814
01/23/23 09:30 PM
01/23/23 09:30 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
If they don't fit then they don't fit regardless of what the mfg tells you. Believe your own eyes not what the sales guy says. i would expect a little more from Barton BUT I cannot count the number of time in the last 25 years I have been told I WAS THE ONLY ONE HAVING THE PROBLEM I actually NAILED Hooker headers on newly designed BB corvette side pipes that didn't fit. SOS as above. Caught them on a corvette forum wanting an original BB car to check side pipe fitment. They did compensate me quite well If other have had the same issue I would suggest collecting some info and going to Ray himself keep us posted
[Re: TJP]
#3115832
01/23/23 10:23 PM
01/23/23 10:23 PM
73cuda340
clarks summit pa
Here are some pictures of the clearance issues. They're not even close to fitting.
[Re: 73cuda340]
#3115838
01/23/23 11:05 PM
01/23/23 11:05 PM
6PKRTSE
Motor City
They are thick enough castings that you could mill/clearance them to fit and re-wrinkle paint.
[Re: moparx]
#3116034
01/24/23 02:27 PM
01/24/23 02:27 PM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
FWIW...I have the Indy valve covers on my hemi...not the ones w/ the clearance notch built into them. I heated and clearanced the inner fender near the shock stud w/ a BFH. I removed the heater & blower motor assembly years ago, so I can't comment on clearance there.
[Re: 71birdJ68]
#3116096
01/24/23 05:24 PM
01/24/23 05:24 PM
73cuda340
clarks summit pa
What kind of issues are you having with the engine? The engine only has 150 street miles on it, zero track time or full throttle blasts and absolutely no beating on the car, and it has already had 6 different rear mail seals installed in it, 4 by me and 2 by Ray himself, 2 different real main seal retainers, and it just pours oil to the point it can't even be driven. Tons of blowby coming out of the breathers , 2 different sets of piston rings installed in it, same issues and this was all at my expense on a brand new engine. I told them I still have the same issues after pulling out the engine 3 different times and going back and forth all the way to their shop just to basically be told tough luck. If you would like to know more about it, I can PM you details. I don't want it to look like a post about me bashing someone or a company.
[Re: 73cuda340]
#3116097
01/24/23 05:28 PM
01/24/23 05:28 PM
an8sec70cuda
Lots of places are having issues getting rear main seals to not leak. Guess it's just poor quality seals. Not taking up for Ray, just saying. Sorry to hear you've had so much trouble w/ it. I know it sucks after making such an investment.
[Re: CrazyD]
#3116098
01/24/23 05:29 PM
01/24/23 05:29 PM
73cuda340
clarks summit pa
Were you able to get the driver's side insulator to sit flat? I recall you reported that issue last Fall. I've been real busy with work, so I haven't had time in the past couple of months to work on it. I'm finally getting back around to it now, but no, the drivers side still sits up about 3/8" to 1/2" off of the k frame. Even if I get this to drop down all of the way, I still don't think it'll be enough to correct the passenger side. I initially considered adding a spacer between the mount, but started to wonder if it would cause any drive train alignment issues since the motor would be shimmed up on the one side. I'm wasnt sure if it would affect the transmission or driveline angle since technically the whole assembly would now be raised on the one side.
