Let’s talk fuel pressure
#3115579
01/23/23 06:45 AM
01/23/23 06:45 AM
Posts: 6,426 Abilene, Texas
fastmark
Abilene, Texas
I’m tuning a set of six pack Holleys so I’d thought I’d try one of those braided line kits from Promax with a built in fuel gauge. My Carter pump that I’ve had on the car for years went up to 8-9 lbs! So I dug out an old Stewart Warner gauge and it reads a steady 9 lbs as well. Seems like I had to get the fuel inlets and needle and seats very tight to keep them from seeping. I also have to turn the the needle and seat way down to get the proper fuel bowl level. I don’t think it’s blowing the needle off the seat at 9 lbs but that sure is a lot of fuel pressure for a Holley to handle. I even tried another used parts house pump I had around the shop that came off a customers car. It was only about 5-6 but before I could really work with that one, I noticed that the pump was leaking all over the floor under the car! That was a scary moment till I got it cleaned up. I thought about trying one of those Edelbrock pumps that advertise 5 psi but flow 40 bpm, but they are pricey at $200. Any thoughts or comments?
The Promax kit with the an fittings leaked. With his supplied aluminum gaskets, it was terrible. I’ve never used those AN fittings before. What is the normal gasket for those that are a direct fit to Holley fuel inlet? I wonder if they use an o ring as well?
Re: Let’s talk fuel pressure
[Re: fastmark]
#3115585
01/23/23 07:40 AM
01/23/23 07:40 AM
Posts: 3,916 usa
lewtot184
usa
6paks came from the factory with a 8-9lb pump, BUT they had a .060" return orifice in the vapor separator that helped control fuel pressure. i just went thru a high pressure fuel thing with one of my street cars. anything over 7lbs can cause problems and seems that 6-6.5lbs is a sweet spot. i use the 6903 pumps and do some mods to them but run a return of some sort. i also think large needle and seats can be a problem with higher pressures. the floats just can't control the flow, especially at WOT. i don't know your power level but stock 6pak fuel lines with the separator can handle 450hp. if you want to keep the braided hose then try to rig up a return line. i prefer hard lines myself, but braided may be better for someone pulling a lot of maintenance.
[Re: lewtot184]
#3115587
01/23/23 07:44 AM
01/23/23 07:44 AM
Posts: 11,644 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Most people run a lot more pressure than they really need.
Don't use Chinese hose and fittings.
[Re: CMcAllister]
#3115592
01/23/23 09:02 AM
01/23/23 09:02 AM
Posts: 3,916 usa
lewtot184
usa
Don't use Chinese hose and fittings. i've got a friend with a big cube oldsmobile who went thru the over kill thing. down sized the fuel delivery and he's very happy with it.
[Re: dvw]
#3115593
01/23/23 09:03 AM
01/23/23 09:03 AM
Posts: 3,916 usa
lewtot184
usa
If you've ever watched a video of 7 psi entering a Holley fuel bowl you would be amaszed. It looks like spraying a garden hose into a dry wash bucket. 5 psi is much calmer. The key is to make sure that you can keep 5 psi constantly. Doug i believe it!
[Re: lewtot184]
#3115601
01/23/23 09:42 AM
01/23/23 09:42 AM
Posts: 1,331 VA
dragon slayer
VA
6paks came from the factory with a 8-9lb pump, BUT they had a .060" return orifice in the vapor separator that helped control fuel pressure. i just went thru a high pressure fuel thing with one of my street cars. anything over 7lbs can cause problems and seems that 6-6.5lbs is a sweet spot. i use the 6903 pumps and do some mods to them but run a return of some sort. i also think large needle and seats can be a problem with higher pressures. the floats just can't control the flow, especially at WOT. i don't know your power level but stock 6pak fuel lines with the separator can handle 450hp. if you want to keep the braided hose then try to rig up a return line. i prefer hard lines myself, but braided may be better for someone pulling a lot of maintenance. The vapor separate comment is misleading, because Mopar fuel pressure spec was measured at inlet to carb and included the separator as part of the system. Hemi pump was 7 to 8.5psi, the 440 HP was 6 to 7.5psi. Mechanical pumps are constant volume pumps. If the diaphram or the airdome age and harden the pressure at outlet rise because less give/expansion of the rubber to buffer the pressure pulse.
[Re: dragon slayer]
#3115630
01/23/23 11:43 AM
01/23/23 11:43 AM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
I put some BLP Bottom Feeder needle and seats in my junk and turned fuel pressure down to 4 psi.
[Re: dragon slayer]
#3115671
01/23/23 01:21 PM
01/23/23 01:21 PM
Posts: 3,916 usa
lewtot184
usa
6paks came from the factory with a 8-9lb pump, BUT they had a .060" return orifice in the vapor separator that helped control fuel pressure. i just went thru a high pressure fuel thing with one of my street cars. anything over 7lbs can cause problems and seems that 6-6.5lbs is a sweet spot. i use the 6903 pumps and do some mods to them but run a return of some sort. i also think large needle and seats can be a problem with higher pressures. the floats just can't control the flow, especially at WOT. i don't know your power level but stock 6pak fuel lines with the separator can handle 450hp. if you want to keep the braided hose then try to rig up a return line. i prefer hard lines myself, but braided may be better for someone pulling a lot of maintenance. The vapor separate comment is misleading, because Mopar fuel pressure spec was measured at inlet to carb and included the separator as part of the system. Hemi pump was 7 to 8.5psi, the 440 HP was 6 to 7.5psi. Mechanical pumps are constant volume pumps. If the diaphram or the airdome age and harden the pressure at outlet rise because less give/expansion of the rubber to buffer the pressure pulse. have you ever had your hands on this stuff and worked with it before?
[Re: lewtot184]
#3115854
01/23/23 11:50 PM
01/23/23 11:50 PM
Posts: 1,331 VA
dragon slayer
VA
6paks came from the factory with a 8-9lb pump, BUT they had a .060" return orifice in the vapor separator that helped control fuel pressure. i just went thru a high pressure fuel thing with one of my street cars. anything over 7lbs can cause problems and seems that 6-6.5lbs is a sweet spot. i use the 6903 pumps and do some mods to them but run a return of some sort. i also think large needle and seats can be a problem with higher pressures. the floats just can't control the flow, especially at WOT. i don't know your power level but stock 6pak fuel lines with the separator can handle 450hp. if you want to keep the braided hose then try to rig up a return line. i prefer hard lines myself, but braided may be better for someone pulling a lot of maintenance. The vapor separate comment is misleading, because Mopar fuel pressure spec was measured at inlet to carb and included the separator as part of the system. Hemi pump was 7 to 8.5psi, the 440 HP was 6 to 7.5psi. Mechanical pumps are constant volume pumps. If the diaphram or the airdome age and harden the pressure at outlet rise because less give/expansion of the rubber to buffer the pressure pulse. have you ever had your hands on this stuff and worked with it before? Yes in great detail documenting fuel pumps and rebuilding them. I have several dozen disassembled and bagged, what do you want to know. Your comment about large and small needles should have been obvious. The same as MC bore. You apply pressure to a surface area. Multiply the area by the pressure and that tells you the force applied to the area. A set pressure against a larger needle means a larger force on the needle. Hence a smaller needle and seat sees a smaller force for a set pressure and therefore less force opening, which means the float can handle keeping the needle shut. High school physics. The same applies inside the fuel pump with the different size chambers, size of the washer plates, and thickness of the air dome gasket. Original carter carbs were designed for a higher pressure, and Chrysler made the move to higher pressure in the 50s. Higher line pressure keeps the fuel in a liquid state when engine compartment gets hot. Less vapor lock. Plenty of good info in the Carter manuals and old Army tech manual.
[Re: lewtot184]
#3115924
01/24/23 08:15 AM
01/24/23 08:15 AM
fastmark
Abilene, Texas
the real issue with 6paks is the screwed up idle circuits. if all your doing is racing maybe you can just do the basics, but for good street driving you really have to go after the emissions built into the circuits. Could you elaborate on this statement. Since this is my thread, I guess it’s ok to highjack it. I have to agree six pack are harder to tune than most. The factory plugged up the idle adjustments screws for the outboards and the center metering block can give lots of trouble with the idle well tubes. The new bilet metering blocks really help the idle circuit, but they don’t look Stock. I’m all ears.
