help with 61 gauges(chrysler)
#311465
05/08/09 06:51 AM
05/08/09 06:51 AM
Posts: 1,012 indiana
mcmopars
indiana
amp gauge works.fuel,oil,gas dont.i have 12 volts to the lead gauge,and a pulsating 6 to the other 2,which i believe to be correct.ground is good to the cluster as my turn signals work.are all 3 bad?? senders are also new.i can ground the gas tank sender and gauge does nothing.im just having a hard time believing all 3 are bad.what are your thoughts?im off to work will check back later
1961 chrysler
1973 duster
1998 ram
2005magnum
2010ram
Re: help with 61 gauges(chrysler)
[Re: mcmopars]
#311468
05/08/09 10:08 PM
05/08/09 10:08 PM
Don't 61 Chryslers have electrolumenescent gauges (lighting strips, no bulbs)? I've never messed with a 61 Chrysler, but my 67 Charger has the electrolumnescent setup. The lighting is high voltage ac, wired in series. Besides the lighting strips, the gauge pointers are "hot" as they light up too. If one gauge goes out, or there is any kind of short anywhere along the way, the oil pressure, temp and gas gauges all quit working. If this doesn't apply to 61 Chryslers, just ignore this post.
[Re: mcmopars]
#311470
05/09/09 02:40 PM
05/09/09 02:40 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I tend to agree that it's pretty unlikely all three gauges went TU but, to eliminate the IVR as the problem, I would hook up a 6V dry cell lantern battery as a power source just to be sure.
[Re: mcmopars]
#311473
07/06/09 02:19 PM
07/06/09 02:19 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
The gauges as said are standard.They have a coating so they glow with the lights for the dash.We bought 2 NOS power packs for the lights.Rocky
Chrysler Firepower
