Re: RPM trace of soft launch
[Re: AndyF]
#3114365
01/19/23 12:14 AM
01/19/23 12:14 AM
Posts: 31,046 Oregon
AndyF
For comparison, here is the same curve from a different car that I tune. This car is roughly the same power to weight ratio but it leaves a lot harder. The RPM curve is very different. I'm suspecting the torque converter but I don't really know, it could be something else. This car has a driveshaft sensor on it. The green line on the screen is the driveshaft speed.
[Re: AndyF]
#3114379
01/19/23 01:59 AM
01/19/23 01:59 AM
Posts: 43,219 Bend,OR USA
Cab_Burge
A little tire spin on the gear change?
[Re: AndyF]
#3114380
01/19/23 02:02 AM
01/19/23 02:02 AM
Cab_Burge
Is it bogging, stumbling, at the hit and then going rich where the round part is from the squirters?
[Re: Cab_Burge]
#3114403
01/19/23 07:32 AM
01/19/23 07:32 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
He might try lowering the 2 step and getting a run at the converter. To me it looks like he is up high in the converter and it is starting to tighten up so it doesn't have as severe of a hook in the RPM maybe?
Here is mine, RPM and Driveshaft. I stall lower and my converter flashes to 6300. 600HP smallblock. From stall speed to flash is .33 seconds
The air was really good in this log, stall was 3550 the flash was 6460 which was the highest I have seen it.
68 Barracuda Formula S 340
[Re: AndyF]
#3114407
01/19/23 08:14 AM
01/19/23 08:14 AM
Posts: 2,924 A shed in England
Tig
A shed in England
For comparison, here is the same curve from a different car that I tune. This car is roughly the same power to weight ratio but it leaves a lot harder. The RPM curve is very different. I'm suspecting the torque converter but I don't really know, it could be something else. This car has a driveshaft sensor on it. The green line on the screen is the driveshaft speed. He's spinning the tyres, D/S trace is "off curve". Starts spinning around 1.2 and recovers by 1.7. The "zero" point (actual start of the pass) is around 0.9. This could be confirmed by a drop in accel G ("g force" on holley). Is it a bias ply tyre getting some wheelspeed, that's whats giving you the rpm "hook" the rpm drops as the tyres stick. EDIT: Below is a dead hook, it shows a nice predictable D/S curve, It's a footbrake launch, a little spin between shifts. The drop first in accel g is due to the front wheels touching down and slowing the car, the other 2 coincide with the gear shift.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3114472
01/19/23 12:36 PM
01/19/23 12:36 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
The top one is likely mostly converter, gearing and carb or a combination of them. The bottom one is wheelspin. If you have the ability to see a accel G meter it will be your friend there. The drop in the driveshaft graph is a great indication that it was spinning the tire, once it bites it pulles the engine and driveshaft down. If you had a G meter to compare it may be a good place to look at the converter as well.
[Re: Cab_Burge]
#3114474
01/19/23 12:40 PM
01/19/23 12:40 PM
Al_Alguire
Las Vegas
A little tire spin on the gear change? Thats not wheelspin on the shift, it is just the way a graph looks on the shift. The slight interruption as the trans goes from gear to gear.
[Re: Al_Alguire]
#3114497
01/19/23 02:28 PM
01/19/23 02:28 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I think there is some confusion, because if you read Andy's original post, the graphs are from two different cars.
He's asking why the launch on the top graph as it transitions from 2 step to stall speed is so rounded off and slow to get there.
The second graph from a different car is just an example of what he thought it would normally look like with a small "spike" after the two step comes off and then it settles in. (which as noted, in this case the driveshaft speed is showing a spike indicating spin also, but that's aside from the question).
As mentioned getting the two step up close to the stall speed will do this. Also if it's in this high 2 step leave, and it dead hooks... it can also cause really really high load on the motor so it won't transition clean off the two step.
I'd try lowering the two step first, but you might need to play with the suspension a little to help it spin. Depending on what it's doing it might like less air in the tire to let it get some wheel speed, or maybe even tighten up the rebound on the shock so it doesn't hit the tire so hard.
Andy you are right it could probably benefit from a slightly looser converter, and slightly more RPM on the shift too, but I don't think that's causing the issue you're pointing out.
[Re: dizuster]
#3114712
01/20/23 12:59 AM
01/20/23 12:59 AM
AndyF
Andy you are right it could probably benefit from a slightly looser converter, and slightly more RPM on the shift too, but I don't think that's causing the issue you're pointing out. I think you are correct. It is a four link car with double adjustable coil over shocks so there is plenty of adjustment that can be made. Lowering the two step makes sense to me since right now there isn't a lot of room between the two step and the stall speed. A looser converter also makes sense as does more RPM at the shift point. I think the car is running low 9's right now but the Moroso calculator says it should run high 8's given the power to weight ratio. So the guy has a few tenths hidden in the chassis, tires, converter, etc.
[Re: AndyF]
#3114773
01/20/23 10:06 AM
01/20/23 10:06 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
IMHO, he's completing the run 200 rpm below peak HP, if he races just 1/8 mile, I would go 10% steeper gear and let it eat! That would solve he soft 60Ft. What gear is in it now?
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3114835
01/20/23 12:23 PM
01/20/23 12:23 PM
AndyF
Joe I think it has 3.90 gears in it right now but I'm not positive. Personally I think it needs a little more gear and a little more stall speed but I could be wrong. Might just need some chassis tuning to loosen things up a little bit.
[Re: AndyF]
#3114844
01/20/23 01:06 PM
01/20/23 01:06 PM
Al_Alguire
Las Vegas
I get that its two different cars and again stand by what I posted. I see a lot of racepak logs for various people who send them to me. While gear is a good idea it still will need some converter work. A large "hump" on a graph is never a good thing and leaves alot of room to improve. A G meter is a very very helpful tool................
[Re: AndyF]
#3114851
01/20/23 01:29 PM
01/20/23 01:29 PM
Posts: 16,928 NC
440Jim
NC
For that combo and 2-speed trans, I think the finish line MPH will increase noticeably with the increase in shift point alone. Get the motor into the higher HP range = more MPH. And MPH at the finish line is nicer for the driver in "dial-in" racing (including index classes).
