RPM trace of soft launch #3114364
01/19/23 12:12 AM
01/19/23 12:12 AM
AndyF Online content OP
AndyF  Online Content OP
Working with a customer who has a car that launches softer than it should. The RPM trace looks odd to me. Usually the RPM trace shows a sharp corner or a small "hook" after the launch but this one is round. I'm thinking maybe the converter is too tight or perhaps the rear gear is too tall and the engine just can't move the car off the line? I'll post a picture of the data log. The log reads from left to right. The first area is the engine on the two step, then the launch, then the 1-2 shift and then the pull to the end.
The second picture is the dyno sheet. The engine makes good power from 6500 to 7500 but this converter stalls around 6000 and the driver is shifting at 7000. So I'm thinking the car would go faster if he shifted at 7500 and ran it thru the lights at 7500. Maybe a higher stall converter also?
Re: RPM trace of soft launch [Re: AndyF] #3114365
01/19/23 12:14 AM
01/19/23 12:14 AM
For comparison, here is the same curve from a different car that I tune. This car is roughly the same power to weight ratio but it leaves a lot harder. The RPM curve is very different. I'm suspecting the torque converter but I don't really know, it could be something else. This car has a driveshaft sensor on it. The green line on the screen is the driveshaft speed.
Re: RPM trace of soft launch [Re: AndyF] #3114379
01/19/23 01:59 AM
01/19/23 01:59 AM
A little tire spin on the gear change?
Re: RPM trace of soft launch [Re: AndyF] #3114380
01/19/23 02:02 AM
01/19/23 02:02 AM
Is it bogging, stumbling, at the hit and then going rich where the round part is from the squirters?
Re: RPM trace of soft launch [Re: Cab_Burge] #3114403
01/19/23 07:32 AM
01/19/23 07:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
He might try lowering the 2 step and getting a run at the converter. To me it looks like he is up high in the converter and it is starting to tighten up so it doesn't have as severe of a hook in the RPM maybe?
Here is mine, RPM and Driveshaft. I stall lower and my converter flashes to 6300. 600HP smallblock. From stall speed to flash is .33 seconds
The air was really good in this log, stall was 3550 the flash was 6460 which was the highest I have seen it.
68 Barracuda Formula S 340
Re: RPM trace of soft launch [Re: AndyF] #3114407
01/19/23 08:14 AM
01/19/23 08:14 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
He's spinning the tyres, D/S trace is "off curve". Starts spinning around 1.2 and recovers by 1.7. The "zero" point (actual start of the pass) is around 0.9.
This could be confirmed by a drop in accel G ("g force" on holley). Is it a bias ply tyre getting some wheelspeed, that's whats giving you the rpm "hook" the rpm drops as the tyres stick.
EDIT: Below is a dead hook, it shows a nice predictable D/S curve, It's a footbrake launch, a little spin between shifts. The drop first in accel g is due to the front wheels touching down and slowing the car, the other 2 coincide with the gear shift.
Re: RPM trace of soft launch [Re: Tig] #3114472
01/19/23 12:36 PM
01/19/23 12:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The top one is likely mostly converter, gearing and carb or a combination of them. The bottom one is wheelspin. If you have the ability to see a accel G meter it will be your friend there. The drop in the driveshaft graph is a great indication that it was spinning the tire, once it bites it pulles the engine and driveshaft down. If you had a G meter to compare it may be a good place to look at the converter as well.
Re: RPM trace of soft launch [Re: Cab_Burge] #3114474
01/19/23 12:40 PM
01/19/23 12:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Thats not wheelspin on the shift, it is just the way a graph looks on the shift. The slight interruption as the trans goes from gear to gear.
Re: RPM trace of soft launch [Re: Al_Alguire] #3114497
01/19/23 02:28 PM
01/19/23 02:28 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I think there is some confusion, because if you read Andy's original post, the graphs are from two different cars.
He's asking why the launch on the top graph as it transitions from 2 step to stall speed is so rounded off and slow to get there.
The second graph from a different car is just an example of what he thought it would normally look like with a small "spike" after the two step comes off and then it settles in. (which as noted, in this case the driveshaft speed is showing a spike indicating spin also, but that's aside from the question).
As mentioned getting the two step up close to the stall speed will do this. Also if it's in this high 2 step leave, and it dead hooks... it can also cause really really high load on the motor so it won't transition clean off the two step.
I'd try lowering the two step first, but you might need to play with the suspension a little to help it spin. Depending on what it's doing it might like less air in the tire to let it get some wheel speed, or maybe even tighten up the rebound on the shock so it doesn't hit the tire so hard.
Andy you are right it could probably benefit from a slightly looser converter, and slightly more RPM on the shift too, but I don't think that's causing the issue you're pointing out.
Re: RPM trace of soft launch [Re: dizuster] #3114565
01/19/23 05:02 PM
01/19/23 05:02 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
The drive shaft speed on my 904 usually looks similar. I've played around with different chips on the 2 step and different 4 link adjustments including shocks. It might look better on the graph but the changes didn't really show up on the time card. Some set ups run quicker with a a little tire spin. My other car with a glide has a smooth graph. I forgot with out looking what the preferred starting line ratio is but the glide is 1.80 low gear. with a 4.56 rear gear. The 904 is 2.45 low with 3.91 rear. I think they're both within range. I've discussed this with several knowledgeable people including Dave Morgan. they told me some cars like a little slip. By the way the 904 (duster) is nose heavy around 60/40. The glide(Daytona) is not.
Re: RPM trace of soft launch [Re: dizuster] #3114712
01/20/23 12:59 AM
01/20/23 12:59 AM
I think you are correct. It is a four link car with double adjustable coil over shocks so there is plenty of adjustment that can be made. Lowering the two step makes sense to me since right now there isn't a lot of room between the two step and the stall speed. A looser converter also makes sense as does more RPM at the shift point.
I think the car is running low 9's right now but the Moroso calculator says it should run high 8's given the power to weight ratio. So the guy has a few tenths hidden in the chassis, tires, converter, etc.
Re: RPM trace of soft launch [Re: AndyF] #3114773
01/20/23 10:06 AM
01/20/23 10:06 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
IMHO, he's completing the run 200 rpm below peak HP, if he races just 1/8 mile, I would go 10% steeper gear and let it eat! That would solve he soft 60Ft. What gear is in it now?
Joe
Without Data, you’re just another guy with an opinion.
Re: RPM trace of soft launch [Re: sr4440] #3114835
01/20/23 12:23 PM
01/20/23 12:23 PM
Joe
I think it has 3.90 gears in it right now but I'm not positive. Personally I think it needs a little more gear and a little more stall speed but I could be wrong. Might just need some chassis tuning to loosen things up a little bit.
Re: RPM trace of soft launch [Re: AndyF] #3114844
01/20/23 01:06 PM
01/20/23 01:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I get that its two different cars and again stand by what I posted. I see a lot of racepak logs for various people who send them to me. While gear is a good idea it still will need some converter work. A large "hump" on a graph is never a good thing and leaves alot of room to improve. A G meter is a very very helpful tool................
Re: RPM trace of soft launch [Re: AndyF] #3114851
01/20/23 01:29 PM
01/20/23 01:29 PM
NC
440Jim Offline
440Jim  Offline
NC
For that combo and 2-speed trans, I think the finish line MPH will increase noticeably with the increase in shift point alone. Get the motor into the higher HP range = more MPH. And MPH at the finish line is nicer for the driver in "dial-in" racing (including index classes).
