B/RB Block girdle #311388
05/07/09 11:26 PM
05/07/09 11:26 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Does a block girdle work on the wedge blocks?
Re: B/RB Block girdle [Re: ChevyTS] #311389
05/07/09 11:35 PM
05/07/09 11:35 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Check out BCR Products, he's a sponsor on this site. Any extra you can do to stiffen the bottom end will help. Only problem with it is you have to cover it up.
Re: B/RB Block girdle [Re: rowin4] #311390
05/07/09 11:48 PM
05/07/09 11:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: B/RB Block girdle [Re: 1_WILD_RT] #311391
05/08/09 12:45 AM
05/08/09 12:45 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
The reason I ask is the only engine that I have used one on is a 9.40 @ 2800 lbs 440 based stroker . When I took the engine apart I found three broken main saddles and more cap walk than I have ever seen. The engine was in the car less than a season. Any idea what might have caused this. The last engine in the same car was a 400 based stroker that ran 9.20s for three seasons and was about 1 point higher compression. Any idea what might have caused this.
Re: B/RB Block girdle [Re: ChevyTS] #311392
05/08/09 12:54 AM
05/08/09 12:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Who's girdle were you running? Obviously something wasn't happy.... All the reports I've heard about BRC's girlde have been positive unless your gonna tell me otherwise...
Re: B/RB Block girdle [Re: ChevyTS] #311393
05/08/09 12:54 AM
05/08/09 12:54 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Lots of good info about this subject. From what I understand there is problem harmonics at the higher hp loads and the RB block have a greater problem than the B blocks. BCR griddle will definitely help or get an after-market block.
Damon
Re: B/RB Block girdle [Re: ChevyTS] #311394
05/08/09 02:29 AM
05/08/09 02:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
BCR aluminum main caps, and girdle
Re: B/RB Block girdle [Re: ChevyTS] #311395
05/08/09 02:42 AM
05/08/09 02:42 AM
Out of the State of Confusion
blue_stocker Offline
Hi TS, was that block using the factory/production caps or were they after-market caps? If they were factory caps and the engine was building more than 550 HP, pretty good bet the factory caps were the culprit! If the girdle wasn't set-up correctly and/or there was a balance/harmonics problem, they probably got shaken hard enough to fracture them FROM the walking about!?! Was the block filled, late 70s block? More issues... ...what about piston to head clearance, rod stretch, head bolts or studs?!
Re: B/RB Block girdle [Re: blue_stocker] #311396
05/08/09 04:23 AM
05/08/09 04:23 AM
Down under
slantman Offline
slantman  Offline
Down under
With the BCR cap/girdle combo and a 4.25" stroke crank, would I be able to use a 1/2" internal oil pick up? Or maybe the 3/8" pickup would be a better fit? My car will be mainly street driven, ocassional blast down the strip, looking at around 600hp at 6000rpm. Would the caps and girdle be a worthwhile investment to go with a '69 RB block?
Sorry for hijacking the thread.
Re: B/RB Block girdle [Re: ChevyTS] #311397
05/08/09 04:36 AM
05/08/09 04:36 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i have used the chenowath 3/8 girdle,stock caps for about 5 yrs with 3 of them beating up on my engine with over 250 passes at over 750 hp.it would be interesting to see the sum of the parts and combonation.not that i can figure out what happined but am interested.
Re: B/RB Block girdle [Re: blownzoom440] #311398
05/08/09 06:51 AM
05/08/09 06:51 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I think the biggest improvement would be going to aluminum main caps. They do not transfer nearly as much punishment to the main webbing of the block. BCR makes a great product, I would get their main caps at least if not their whole setup if an aftermarket block is out of the question.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: B/RB Block girdle [Re: 1_WILD_RT] #311399
05/08/09 11:20 AM
05/08/09 11:20 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Not sure on the brand name. The last thing I want to do is derate some ones product. Im trying to find out if factory blocks are usless for the HP level that my combo is in.
T & K Performance
Re: B/RB Block girdle [Re: blownzoom440] #311400
05/08/09 11:25 AM
05/08/09 11:25 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Its a 4.5 stroke with 6.8 rod custom Diamond and stage six maxwedge heads. 3/4 fill on the block.
Re: B/RB Block girdle [Re: ChevyTS] #311401
05/08/09 11:39 AM
05/08/09 11:39 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
ChevyTS, I'd say you are definitly pushing the envelope on too much power for a stock block, but I'm suprised it has showed up that quick and to the degree mentioned, from my experiences detonation is a huge factor in capwalk, how much timing were you running? Compression ratio? Fuel? I think that a stock block does pretty well in high HP situations where it's not being run on the edge to get every bit of power, if I was running an index, heads up, ect where I was run on the ragged edge I'd for sure go aftermarket if the rules allowed, I think that there is a difference in block damage with the same HP out put depending how that engine is tuned. I'd be pretty unhappy though if I was in your predicament, you have some added "safety margin" in the girdle, but it didn't do what it should have done evidently.
Re: B/RB Block girdle [Re: ChevyTS] #311402
05/08/09 12:06 PM
05/08/09 12:06 PM
AndyF Online content
AndyF  Online Content
The long stroke might be the problem. Back it down to a 4.25 stroke and the stock block will probably last longer for you. With those heads you probably won't lose any power with the shorter stroke anyway.
Re: B/RB Block girdle [Re: ChevyTS] #311403
05/08/09 12:10 PM
05/08/09 12:10 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yep, you are way past where a stock 440 block is iffy. Could last hundreds of passes or one night. If the stock block was reliable for this type of engine there would be very little market for aftermarket blocks.
It did however keep a bunch of oil and parts off the track. Without the girdle he might have run over his crank and gone for a very nasty ride.
Re: B/RB Block girdle [Re: AndyF] #311404
05/08/09 12:41 PM
05/08/09 12:41 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
The car ran 9.60 with the 4.150 stroke.
Re: B/RB Block girdle [Re: GomangoCuda] #311405
05/08/09 12:44 PM
05/08/09 12:44 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I think your right. I will have to step to an aftermarket block.
Re: B/RB Block girdle [Re: wyoming] #311406
05/08/09 12:49 PM
05/08/09 12:49 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Im sure timing and rpm was a factor. I just installed a chassis dyno at my shop. I think I will give it one more try and keep a closer eye on the tune. Thanks for the in put. BTW nice car.
