Re: B/RB Block girdle
[Re: ChevyTS]
#311393
05/08/09 12:54 AM
05/08/09 12:54 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello,
Lots of good info about this subject. From what I understand there is problem harmonics at the higher hp loads and the RB block have a greater problem than the B blocks. BCR griddle will definitely help or get an after-market block.
Damon
[Re: blownzoom440]
#311398
05/08/09 06:51 AM
05/08/09 06:51 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I think the biggest improvement would be going to aluminum main caps. They do not transfer nearly as much punishment to the main webbing of the block. BCR makes a great product, I would get their main caps at least if not their whole setup if an aftermarket block is out of the question.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: blownzoom440]
#311400
05/08/09 11:25 AM
05/08/09 11:25 AM
Posts: 576 Texas
ChevyTS
Texas
i have used the chenowath 3/8 girdle,stock caps for about 5 yrs with 3 of them beating up on my engine with over 250 passes at over 750 hp.it would be interesting to see the sum of the parts and combonation.not that i can figure out what happined but am interested.
Its a 4.5 stroke with 6.8 rod custom Diamond and stage six maxwedge heads. 3/4 fill on the block.
[Re: ChevyTS]
#311401
05/08/09 11:39 AM
05/08/09 11:39 AM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
ChevyTS, I'd say you are definitly pushing the envelope on too much power for a stock block, but I'm suprised it has showed up that quick and to the degree mentioned, from my experiences detonation is a huge factor in capwalk, how much timing were you running? Compression ratio? Fuel? I think that a stock block does pretty well in high HP situations where it's not being run on the edge to get every bit of power, if I was running an index, heads up, ect where I was run on the ragged edge I'd for sure go aftermarket if the rules allowed, I think that there is a difference in block damage with the same HP out put depending how that engine is tuned. I'd be pretty unhappy though if I was in your predicament, you have some added "safety margin" in the girdle, but it didn't do what it should have done evidently.
[Re: ChevyTS]
#311403
05/08/09 12:10 PM
05/08/09 12:10 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Yep, you are way past where a stock 440 block is iffy. Could last hundreds of passes or one night. If the stock block was reliable for this type of engine there would be very little market for aftermarket blocks.
It did however keep a bunch of oil and parts off the track. Without the girdle he might have run over his crank and gone for a very nasty ride.
[Re: AndyF]
#311404
05/08/09 12:41 PM
05/08/09 12:41 PM
Posts: 576 Texas
ChevyTS
Texas
The long stroke might be the problem. Back it down to a 4.25 stroke and the stock block will probably last longer for you. With those heads you probably won't lose any power with the shorter stroke anyway.
The car ran 9.60 with the 4.150 stroke.
[Re: GomangoCuda]
#311405
05/08/09 12:44 PM
05/08/09 12:44 PM
Posts: 576 Texas
ChevyTS
Texas
I think your right. I will have to step to an aftermarket block.
[Re: wyoming]
#311406
05/08/09 12:49 PM
05/08/09 12:49 PM
Posts: 576 Texas
ChevyTS
Texas
Im sure timing and rpm was a factor. I just installed a chassis dyno at my shop. I think I will give it one more try and keep a closer eye on the tune. Thanks for the in put. BTW nice car.
