904 Direct Drum Wound Spring #3111457
01/13/23 07:07 AM
01/13/23 07:07 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I see there is a REVERSE wound spring available to remedy the high RPM issue with the std. wound spring.
Is it effective for the issue?
Or is the 24 spring update and peices the only way to go???.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 904 Direct Drum Wound Spring [Re: 6bblFLASH] #3111459
01/13/23 07:12 AM
01/13/23 07:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The reasoning makes sense to me, but I went ahead and went with the multi spring deal from A&A. I have been real happy with it. My 904 is stock with that spring pack, a TA valve body, and red clutches. Heavy street car raced occasionally and its been trouble free.
It also has the late model style pump drive. That's the real problem I have had with 904s over the years, broken converter snouts.
68 Barracuda Formula S 340
Re: 904 Direct Drum Wound Spring [Re: 6bblFLASH] #3111477
01/13/23 09:36 AM
01/13/23 09:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
A friend in Vegas ran them in all three of his race cars….. mine has the A&A pack. Just tore my 904 down for a peek after 84 passes. Looked like new. Pretty much a stock component trans other than the aforementioned spring pack and Pro Trans valve body. Just hope my shafts keep on keeping on!
Re: 904 Direct Drum Wound Spring [Re: J_BODY] #3111489
01/13/23 10:41 AM
01/13/23 10:41 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
There's different reverse wound springs for the 904. I've tried several but I like my A&A best,
