Cam position relative to lifter bore #3110381
01/09/23 04:30 PM
01/09/23 04:30 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Is there a way to move the cam fwd in the block to get the cam lobes lined up center to the lifter bores?
My cam looks like it needs to go about .125 to .25 fwd to line the lobes with the lifter bores
Re: Cam position relative to lifter bore [Re: RATTRAP] #3110384
01/09/23 04:42 PM
01/09/23 04:42 PM
Washington
madscientist Offline
Washington
If it’s a flat tappet cam they can’t be lined up. If it’s a roller then yes, they should be centered.
Re: Cam position relative to lifter bore [Re: madscientist] #3110479
01/10/23 12:11 AM
01/10/23 12:11 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
If you do this, check timing set gear alignment. I guess do it anyway. I needed to shim my crank sprocket for timing set in order to align with cam timing gear.
Re: Cam position relative to lifter bore [Re: INTMD8] #3110514
01/10/23 09:22 AM
01/10/23 09:22 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
I thought flat tappet lifters were offset from the lobe centerline to make them spin.
Re: Cam position relative to lifter bore [Re: hemienvy] #3110516
01/10/23 09:44 AM
01/10/23 09:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Nope. The bevel on the lobes and the convex face of the lifter are what do that.
Re: Cam position relative to lifter bore [Re: RATTRAP] #3110517
01/10/23 09:53 AM
01/10/23 09:53 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The key words here are "looks like". Moving the cam either way will move the oil feed holes in the cam relative to the ones in the cam journal decreasing or cutting off oil to the top end. It will move the oil pump drive gear contact point. And then there's the timing set which will probably now hit the cover and possibly not allow the balancer to properly seat which will change all your pulley alignment.
Why don't you take your issue to the right place ... the cam manufacturer !!
Re: Cam position relative to lifter bore [Re: Stanton] #3110529
01/10/23 10:36 AM
01/10/23 10:36 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
You bring up some very good points, I will do some more measurement's before I go after the cam manufacturer, could be the lifter bores in the block were drilled incorrect.
Re: Cam position relative to lifter bore [Re: RATTRAP] #3110589
01/10/23 02:07 PM
01/10/23 02:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What block is it?
Re: Cam position relative to lifter bore [Re: Al_Alguire] #3110747
01/11/23 07:50 AM
01/11/23 07:50 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Originally Posted by Al_Alguire
What block is it?
KB Alum 426
Re: Cam position relative to lifter bore [Re: RATTRAP] #3110905
01/11/23 04:56 PM
01/11/23 04:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So my next question is it a new or older version
Re: Cam position relative to lifter bore [Re: Al_Alguire] #3111159
01/12/23 12:58 PM
01/12/23 12:58 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
this is a 2012 alum block from KB
