MSD cam sync #3109955
01/08/23 12:09 AM
01/08/23 12:09 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Currently rewiring my car to a new EFI system. Curious if anyone had modified a msd 85231 to work in a low deck?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: MSD cam sync [Re: HOTMOPR] #3109957
01/08/23 12:43 AM
01/08/23 12:43 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Have you considered AR engineering's cam sync ?
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: MSD cam sync [Re: turbobitt] #3109961
01/08/23 12:57 AM
01/08/23 12:57 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
AG.
Ill check it out. Thanks
Re: MSD cam sync [Re: HOTMOPR] #3109984
01/08/23 07:13 AM
01/08/23 07:13 AM
AndyF Offline
AndyF  Offline
I make a low deck version. Talk to Rich at FAST Man EFI about cam sync and crank triggers. He can tell you what will work best for your application. He handles FAST and Holley EFI products as well as some of the other ones.
https://arengineering.com/products/cam-sync-b-and-rb-engines/
Re: MSD cam sync [Re: HOTMOPR] #3110021
01/08/23 11:50 AM
01/08/23 11:50 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
In the midst of doing exactly that right now. I made a set of holding blocks for the mill so I could cut off the drive tip and remachine it as I didn't want to use a distributor spacer. Just finishing the blocks now so I will post pics after it's cut.
Hutch
Re: MSD cam sync [Re: Hutch] #3110058
01/08/23 01:35 PM
01/08/23 01:35 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
IMO the AR part is of higher quality.
Re: MSD cam sync [Re: AndyF] #3110164
01/08/23 07:53 PM
01/08/23 07:53 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I am currently running the SD concepts Crank trigger and cam sync. The sensors have been working great. I am just looking for options other than the ugly jeep sensor. lol
Re: MSD cam sync [Re: Hutch] #3110169
01/08/23 08:09 PM
01/08/23 08:09 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Hutch
drive
