comp 901-16 drop on a stock head with no machine work and use stock locks/retainer and valve seals
wish I had done more home work when I went roller cam,the lunati springs were double with a damper and need machine work and pc seal
I did the cam swap with out R&R the heads so I need a drop on spring
they were with in 10 plbs of the lunati spring rate...so lunati uses the same spring for all the sb cams,flat or roller
now I got 130$ double springs and damper for door stops
but yes need to match the spring rate to cam specs
seems the comp springs will handle all the cams I have looked at for the sb that are not to radical of a cam
need some doubls with a damper?
