valve springs? #310828
05/07/09 08:52 AM
05/07/09 08:52 AM
montreal, quebec, canada
jimmy71demon Offline OP
i plan on using my j heads on my 416 (340 stroker) and dont know what to use for springs... any ideas guys? also is there anything else i should do to the heads?
Im goin fast Mom!
Re: valve springs? [Re: jimmy71demon] #310829
05/07/09 08:55 AM
05/07/09 08:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What CAM are you using ??? Get the springs the cam maker recommends ...
Re: valve springs? [Re: JohnRR] #310830
05/07/09 09:30 AM
05/07/09 09:30 AM
Dallas, TX
Hubbs Offline
Hubbs  Offline
Dallas, TX
Agree: Contact the cam manufacturer. They will tell you exactly what you need.
I used to be "Chubs". Sorry I've been away for so long! I got married and am now "Hubbs"! Garage: 1970 Dodge Challenger 440/4sp 2013 Dodge Charger SRT-8 2014 Ram 1500 2015 SRT Challenger Hellcat (on order)
Re: valve springs? [Re: Hubbs] #310831
05/07/09 10:30 AM
05/07/09 10:30 AM
scratchnfotraction Offline
comp 901-16 drop on a stock head with no machine work and use stock locks/retainer and valve seals
wish I had done more home work when I went roller cam,the lunati springs were double with a damper and need machine work and pc seal
I did the cam swap with out R&R the heads so I need a drop on spring
they were with in 10 plbs of the lunati spring rate...so lunati uses the same spring for all the sb cams,flat or roller
now I got 130$ double springs and damper for door stops
but yes need to match the spring rate to cam specs
seems the comp springs will handle all the cams I have looked at for the sb that are not to radical of a cam
need some doubls with a damper?
Re: valve springs? [Re: scratchnfotraction] #310832
05/07/09 12:07 PM
05/07/09 12:07 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Comp 901s are similar to the Lunatis duals, but not strong enough for any profile larger than the XE268 they sell. They are a basic performance spring, nothing fancy or stiff.
On the J heads... You will need double springs for the cam that 416 should be getting (something larger than 245°@.050, which is very mild for a 4" arm). So have the spring seats cut and the guides reduced in size for them. Then get the springs the cam manufacturer says to.
